| ISM Cal File Needed |
| 12-21-2022, (Subject: ISM Cal File Needed ) Post: #10 | |||
| RE: ISM Cal File Needed I’m pretty sure it’s an Ism because ecm is a CM570. But will make sure tomorrow morning. Cpl on dataplate seems for L10. Maybe PO swapped rocker housing? Are they compatible? Will try to find the esn on block as you said. Hopefully I have some new tomorrow. Appreciate the help. (12-21-2022 )Bengy88 Wrote: Im assuming this is an m11, the esn should be on the rear corner of the block right under the head. I think its drivers side on those engines but may be passenger. You will probably need a wire brush | |||
| 12-30-2022, (Subject: ISM Cal File Needed ) Post: #11 | |||
| RE: ISM Cal File Needed L20302 Cpl doesn’t match | |||
| 12-31-2022, (Subject: ISM Cal File Needed ) Post: #12 | |||
| RE: ISM Cal File Needed | |||
| 01-01-2023, (Subject: ISM Cal File Needed ) Post: #13 | |||
| RE: ISM Cal File Needed You should be in this area somewhere It’s your cpl | |||
| 01-01-2023, (Subject: ISM Cal File Needed ) Post: #14 | |||
| RE: ISM Cal File Needed From what I could tell you have an M11 longblock with CM570 controls. Please understand that this calibration has three different variations for an auto trans and different power curves. I'm assuming you're linehaul with a manual transmission. Here is what I came up with: ECM# 3681405 Current calibration: L20302.37 330HP 1250TQ at 1,800RPM DO: 02103 SC: 20069 FR: 02584 CPL: 2607 Replacement calibration: L21133.16 330HP 1250TQ at 1,800RPM DO: 02103 SC: 20076 FR: 02657 CPL: 2607 You should be able to download that calibration off QSOL. If not, PM me and I'll send it to you. User's Signature: I won the internet once. | |||
| 01-02-2023, (Subject: ISM Cal File Needed ) Post: #15 | |||
RE: ISM Cal File Needed (01-01-2023 )Aleeex Wrote: You should be in this area somewhere The B20047 file shows that it is not meant for a ism with a CM570 ecm, but instead, it is for a Celect with an ECMB model ecm. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 01-03-2023, (Subject: ISM Cal File Needed ) Post: #16 | |||
| 01-03-2023, (Subject: ISM Cal File Needed ) Post: #17 | |||
RE: ISM Cal File Needed (01-03-2023 )Aleeex Wrote: ... yeah.. some engines might have some of the same hardware .. but do have a different ecm and wiring harness. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 03-30-2026, (Subject: ISM Cal File Needed ) Post: #18 | |||
| RE: ISM Cal File Needed hello, does anybody have L20296? | |||
