EGR hose leaking fluid |
02-26-2023, (Subject: EGR hose leaking fluid ) Post: #10 | |||
RE: EGR hose leaking fluid (02-25-2023 )Rawze Wrote: Is your crank case filter a maintenance free one?... if not then it might need to be changed..,as it can cause a lot of oil leaks on the engine as crank case fumes build up.My crank case filter is maintenance free yep. Took a photo of the bolt that is leaking. I had an overhead done not long ago and the mechanic told me I had leaking bolts on the back and this bolt looks new too | |||
02-26-2023, (Subject: EGR hose leaking fluid ) Post: #11 | |||
RE: EGR hose leaking fluid Must be a bad valve cover gasket. | |||
02-26-2023, (Subject: EGR hose leaking fluid ) Post: #12 | |||
RE: EGR hose leaking fluid | |||
02-26-2023, (Subject: EGR hose leaking fluid ) Post: #13 | |||
RE: EGR hose leaking fluid (02-26-2023 )Josiah Harder Wrote: Well that is better than a leaking EGR cooler I guess haha Yep, 100% lol.... Pull the cover, clean the surface on the head really good and make sure that gasket is seated properly in the valve cover channel (although the damage already be done if its pinched). When reinstalling, be sure to follow Cummins tightening sequence and torque specs. Should be able to stop the leak if it is for sure whats leaking. | |||
