Cm570 engine brake vibration and weak jakes
10-09-2023, (Subject: Cm570 engine brake vibration and weak jakes )
RE: Cm570 engine brake vibration and weak jakes
I could swap injectors over from another cylinder before buying a brand new oem one just to see what happens to the bubbles.
Im wondering if it could be a crack in the head?
be sure to adjust the overhead valves and injector rockers to correct torque before doing the tests as well. It can effect the test.
 Thanks given by: Marat
I adjusted everything after swapping injectors, still stuck with the bubbles
10-10-2023, (Subject: Cm570 engine brake vibration and weak jakes )
(10-09-2023 )Marat Wrote:  I adjusted everything after swapping injectors, still stuck with the bubbles
I have done that test many many times over the years.
Only conclusion that I would assume is that then you have leaky injectors or possibly a cracked head.
I would point towards leaky injectors if they are not OEM. I am not a fan of repaired or non eom injectors or other critical components like that. They don't last for s#it and it always costs everyone a lot more moneys in the end, in one way or another.
Around here, we call it jumping over a dollar to save a dime.
 Thanks given by: Marat , Pd6cas2
