|     motor shutting off intermittently while driving isx15    |
|    02-13-2024, (Subject: motor shutting off intermittently while driving isx15 )   Post: #10   |  |||
|  RE: motor shutting off intermittently while driving isx15    Absolutely..... it slowly tearing it's guts out the whole time.     |  |||
|    02-13-2024, (Subject: motor shutting off intermittently while driving isx15 )   Post: #11   |  |||
 RE: motor shutting off intermittently while driving isx15  (02-13-2024 )aarmon8908 Wrote:(02-11-2024 )Rawze Wrote: ... ABSOLUTELY.. Your statement just above is the same as someone saying.. "If I don't ever look at my oil, ..and the engine seems to run just fine for the last 100,000+ miles ... then the oil must not be going bad and not causing any damage that I can feel from driving it so far .. so it still must be doing its job right??. KNOWING SOMETHING FOR SURE, BECAUSE YOU HAD IT PROPERLY CHECKED OUT ... AND ASSUMING ALIKE A FOOL BECAUSE YOU GOT AWAY WITH IT SO FAR ARE 2 VERY DIFFERENT THINGS!!! You now have the ability to know .. instead of assume. - Never assume, especially with something well known to be more than 90% likely bad and harmful. It costs someone dearly in the end, and they end up learning something the hard way financially. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!.  |  |||
|    02-15-2024, (Subject: motor shutting off intermittently while driving isx15 )   Post: #12   |  |||
 RE: motor shutting off intermittently while driving isx15  (02-11-2024 )Rawze Wrote: ... What’s your email?  |  |||
|    02-15-2024, (Subject: motor shutting off intermittently while driving isx15 )   Post: #13   |  |||
|  RE: motor shutting off intermittently while driving isx15    User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!.  |  |||
|    02-22-2024, (Subject: motor shutting off intermittently while driving isx15 )   Post: #14   |  |||
 RE: motor shutting off intermittently while driving isx15  (02-11-2024 )Rawze Wrote:(02-11-2024 )aarmon8908 Wrote: My mechanic has already checked the battery connections. I will get him to recheck the starter cables tomorrow. I did just recently buy an ecm, but I wanted to try EVERYTHING first before taking my truck 4 hours away to the tuner (Trucks deleted) This is the original ecm and I've driven the truck about 160k mi since the delete with no issues until recently I have inline software in my laptop. can you show me how to copy my ecm original program to video. i had original program on it  |  |||
|    02-23-2024, (Subject: motor shutting off intermittently while driving isx15 )   Post: #15   |  |||
 RE: motor shutting off intermittently while driving isx15  (02-22-2024 )nirubini Wrote: ... this post may help... ref: http://rawze.com/forums/showthread.php?t...5#pid72945 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!.  |  |||
|    02-23-2024, (Subject: motor shutting off intermittently while driving isx15 )   Post: #16   |  |||
|  RE: motor shutting off intermittently while driving isx15    Wow, it's kind of wild that you've already swapped out a bunch of throttle-related parts. And hearing that others on a forum had similar issues and fixing the ECM power wire helped them out, that's definitely worth considering for your situation too.     |  |||
