ISX 12 code 4726 and 0559 |
03-06-2025, (Subject: ISX 12 code 4726 and 0559 ) Post: #10 | |||
RE: ISX 12 code 4726 and 0559 I replaced the high pressure fuel pump. Mostly have the same results. Still has low rail pressure. I ran the injector leak off test and it set 2 new codes. Codes 3741 and 3727 and still has the 0559. I ran the cylinder cut off test and when I cut off #6 the rail pressure becomes almost even with actual vs commanded. I then capped off the the common rail going to #6 injector and actual vs commanded is almost even. When I take the cap off #6 and try to start the engine it will not restart and has low rail cranking pressure. Put cap back on #6 and it will restart. Am I wrong in thinking I need to replace injector #6. I have cut off and capped all other cylinders with little to no change in actual rail pressure. I have 3 sister trucks and I am thinking to swap one injector at a time and see what happens. | |||
03-06-2025, (Subject: ISX 12 code 4726 and 0559 ) Post: #11 | |||
03-06-2025, (Subject: ISX 12 code 4726 and 0559 ) Post: #12 | |||
RE: ISX 12 code 4726 and 0559 do an injector leak test same as this video shows... info: http://rawze.com/forums/showthread.php?t...3#pid75483 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
