| CM871 turbo premature bearing failure |
| Yesterday, (Subject: CM871 turbo premature bearing failure ) Post: #19 | |||
| RE: CM871 turbo premature bearing failure I don't follow OE pricing very close, but it seems like maybe the prices have softened a tad? $5500-6k range for 871 era RX turbos. My YTS failed - not because of craftmanship, but because of the vgt assembly. The studs became loose and wallowed out. On tear down, I was amazed it was still working at all - it only stuck when doing sweeps cold. Out of any non OE rebuilder independent shops, I'd lean toward YTS being the most meticulous during balancing and assembling, but he has the same problem all other rebuilders have - no access to genuine parts. Mcbee, HD, etc all rely on aftermarket VGT rings and vanes, etc. I even see Bullydog jumping in selling aftermarket crap at nearly OE pricing. | |||
| Today, (Subject: CM871 turbo premature bearing failure ) Post: #20 | |||
RE: CM871 turbo premature bearing failure (Yesterday )Nostalgic Wrote: ...My YTS failed - not because of craftmanship, but because of the vgt assembly. The studs became loose and wallowed out... What kind of mileage (or time depending on how you run), did you see out of your YTS? (Yesterday )Nostalgic Wrote: Out of any non OE rebuilder independent shops, I'd lean toward YTS being the most meticulous during balancing and assembling, but he has the same problem all other rebuilders have - no access to genuine parts. Mcbee, HD, etc all rely on aftermarket VGT rings and vanes, etc. I even see Bullydog jumping in selling aftermarket crap at nearly OE pricing. Yep you're right on pricing...they're up there. If everything goes well with my core, I'll be about 5k deep with turbo and actuator from YTS. However, if it serves me well, it beats the alternatives. My local Cummins dealer claimed they had no RX available for my setup (cm2350), and the new prices are astronomical! If a reg guy rolls into the dealer to replace the turbo/actuator, it would cost 15k+ between parts, labor and sales tax. Seriously unbelievable. | |||
| Today, (Subject: CM871 turbo premature bearing failure ) Post: #21 | |||
| RE: CM871 turbo premature bearing failure I couldn't answer you very accurately. I've lost track over the years when and what I was running and for how long. I'd guess that I probably had 150-200k on it. Of course that's over several years, I don't put many miles on. I've been hesitant to even say on here that it failed, because I really do believe he does an excellent job. I'd buy another from him again without hesitation - I just don't expect as long of service life as a new oe holset. Funny story about that particular turbo. I bought parts online and rebuilt it myself - I'm just terrified to bolt it on and try it haha. It's in the SHTF storage boxes just in case I need a whistle whirley smoke spinner in a dystopian future. If my current turbo needs replacing, I'm calling YTS first. | |||
