I found the Ambient Air Temp Sensor! 2008 ProStar...
06-03-2017, (Subject: I found the Ambient Air Temp Sensor! 2008 ProStar... )
Post: #19
RE: I found the Ambient Air Temp Sensor! 2008 ProStar...
(06-03-2017 )mikealike Wrote:  I might be a noob here but where does it display at on the 11 Prostar? I've owned this one and never seen a temp display, thanks
It should be on your instrument cluster, the small LED screen that displays your mileage. It should be in the bottom left corner of that screen.
 Thanks given by: mikealike
Post: #20
I will take a look, thanks
04-18-2018, (Subject: I found the Ambient Air Temp Sensor! 2008 ProStar... )
Post: #21
I have a 2010 prostar, and have never seen a temp display on the screen. It is going 5 years that I have this truck. Maybe that is why I have AC issues every year?
Post: #22
(04-18-2018 )74bassman Wrote:  I have a 2010 prostar, and have never seen a temp display on the screen. It is going 5 years that I have this truck. Maybe that is why I have AC issues every year?
Could very well be... It is tied into the AC system if you look at the schematics.
Post: #23
Would that also be the reason I haven't seen the temp on the screen?
Post: #24
(04-18-2018 )74bassman Wrote:  Would that also be the reason I haven't seen the temp on the screen?
It could be, or possibly something else, will have to look at the schematics. The wiring on these things is right out of a bad Frankenstein movie. Your ABS and Jake run through your compass, no telling what the temp sensor runs through... Probably the blinker fluid control unit. ;-)
 Thanks given by: Brock
Post: #25
since when is there a compass on this truck??
Post: #26
It’s in your fuse panel, in the passenger side dash.... 2 screws hold it in, black plastic thing... Above fuses, in lip of dash, 2 torx screws. I’ll show you tomorrow, bring case of Heineken. ;-)
04-19-2018, (Subject: I found the Ambient Air Temp Sensor! 2008 ProStar... )
Post: #27
It is going have to wait, maybe I can run by there on Friday am. I found this sensor right where you said. Now I'm scared to cut wires to make it fit up on the windshield cowl.
