Help low boost
02-24-2016, (Subject: Help low boost )
Post: #19
RE: Help low boost
voltage to actuator signal voltage can read 0 on alot of them, but the position meatured must match commanded.
Post: #20
RE: Help low boost
(02-24-2016 )Marajin Wrote:
(02-24-2016 )gonzo1949 Wrote:  Also 0.0 crankcase pressure.
0.0 for the cc pressure senor
0.0 for turbo actuator signal sensor
Those are all normal.
9
turbo actuator signal sensor > not used by computer because it is J1939 instead.
cc pressure senor/crankcase pressure > not used after that type of custom tuning. unrelated.
Ok so those are unrelated. Does it sound like a bad actuator?
Post: #21
RE: Help low boost
Try doing turbo test see what happens.
Post: #22
RE: Help low boost
(02-24-2016 )gearhead Wrote:  voltage to actuator signal voltage can read 0 on alot of them, but the position meatured must match commanded.
Ok so my commanded actuator position is always on 5% . It does not move up or down no matter what position the throttle is in. If the actuator went bad would the ecm command as normal?
Post: #23
RE: Help low boost
What is the turbo test?
Post: #24
RE: Help low boost
IN insite there is turbo test or hysteris test to make sure turbo is working or calibrated.
Post: #25
RE: Help low boost
OK gonna check
Post: #26
RE: Help low boost
The only one I see is the calibration test
Post: #27
RE: Help low boost
ok try the calibration last test for after actuator is installed.
