EGR cooler alternative.
02-10-2021, (Subject: EGR cooler alternative. )
Post: #19
RE: EGR cooler alternative.
(02-10-2021 )Smiling lemon Wrote:  Then i will order 10 mm thick stainless disks to weld in the but i can not order till i know what size the orifice is at inlet and outlet.
just go home pull it off measure it with calipers get some metal and a proper sized hole saw from lowes then weld away
Post: #20
Why not just remove the problem and run a coolant line in its place?
