| ISM Cal File Needed |
| 03-30-2026, (Subject: ISM Cal File Needed ) Post: #19 | |||
| RE: ISM Cal File Needed | |||
| 03-30-2026, (Subject: ISM Cal File Needed ) Post: #20 | |||
| RE: ISM Cal File Needed This one is no longer available my incal. thats why i was looking for someone that may have a previous version of incal. | |||
| 03-30-2026, (Subject: ISM Cal File Needed ) Post: #21 | |||
RE: ISM Cal File Needed (03-30-2026 )komatsudiag Wrote: hello, does anybody have L20296? A lot of those old programs are not around any more because the compression ratio on the overhaul kits for them have been updated (higher compression ratio and more standardized overhaul kits on those old engines need updated programs as well). - Find the modern, still available program crossover and use that program instead. - If your not sure, you can always get a gold of cummins directly and have them tell you what program that is currently available to use in it. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
