| CM2250, fuel leak mystery, please help!! |
| 02-01-2018, (Subject: CM2250, fuel leak mystery, please help!! ) Post: #28 | |||
| RE: CM2250, fuel leak mystery, please help!! Yes, I would say next time I pull injectors I will replace the rest. User's Signature: Anti-seize EVERYTHING, Except injectors...Use Petroleum Jelly!!! | |||
| 02-01-2018, (Subject: CM2250, fuel leak mystery, please help!! ) Post: #29 | |||
RE: CM2250, fuel leak mystery, please help!! (02-01-2018 )JMBT Wrote: ... fla to az and only 30k in the box? even at 60-62 I would be busting 8.3 - 8.9~ish average to the pump easily (and above 9.x between fla and texas) with my 871. You guys would have both been crying and wondering wondering WTF?. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 02-01-2018, (Subject: CM2250, fuel leak mystery, please help!! ) Post: #30 | |||
| RE: CM2250, fuel leak mystery, please help!! I think Rawze should sell properly set up trucks to us owner operators. The savings alone in fuel and maintaince would pay for whatever price he thought of. I to am a victim of the 2250, and believed all the lies and hype. Now that I have seen the truth, I picked up an 09 with an ISM and will be downgrading to lots of sleep and no worries | |||
| 02-02-2018, (Subject: CM2250, fuel leak mystery, please help!! ) Post: #31 | |||
| RE: CM2250, fuel leak mystery, please help!! 8 (01-29-2018 )JMBT Wrote: So here are the parts I just got from Cummins. $172 worth. From left to right, $70, $12, $70. Plus freight & tax. Of course in true Cummins fashion they all need primer and paint, so I am outside at the truckstop painting them on some cardboard in the dirt. I will install them tomorrow, hopefully the end of leaky number 5. What size socket is needed for the part in the middle? I know fuel lines use 7/8 crows foot... | |||
| 02-03-2018, (Subject: CM2250, fuel leak mystery, please help!! ) Post: #32 | |||
RE: CM2250, fuel leak mystery, please help!! (02-02-2018 )jimeneztrans84 Wrote: 81 1/16 socket.(01-29-2018 )JMBT Wrote: So here are the parts I just got from Cummins. $172 worth. From left to right, $70, $12, $70. Plus freight & tax. Of course in true Cummins fashion they all need primer and paint, so I am outside at the truckstop painting them on some cardboard in the dirt. I will install them tomorrow, hopefully the end of leaky number 5. | |||
| 02-03-2018, (Subject: CM2250, fuel leak mystery, please help!! ) Post: #33 | |||
| RE: CM2250, fuel leak mystery, please help!! Or you can go metric. 22mm crow’s foot on the fuel line, and 27mm deep socket on the retainer nut. User's Signature: Anti-seize EVERYTHING, Except injectors...Use Petroleum Jelly!!! | |||
