| Oil Temp Overheating issue |
| 07-20-2020, (Subject: Oil Temp Overheating issue ) Post: #28 | |||
| RE: Oil Temp Overheating issue Thanks for replying Radiator is replaced last year along with it a new oil cooler and thermostat And Cummins inspect main bearing according to them bottom of engine is in good shape I change my oil every 15000 to 17000 miles Will do a coolant flush when go back to home this week | |||
| 07-20-2020, (Subject: Oil Temp Overheating issue ) Post: #29 | |||
| RE: Oil Temp Overheating issue I thought mine temp was bad a 200. | |||
| 07-20-2020, (Subject: Oil Temp Overheating issue ) Post: #30 | |||
| RE: Oil Temp Overheating issue 200° oil temp is low. You should be at least above water boiling temp to stave of moisture collecting in the oil. | |||
| 07-20-2020, (Subject: Oil Temp Overheating issue ) Post: #31 | |||
| RE: Oil Temp Overheating issue Could be a cam bearing out or a gear train bearing there's more then just rod/mains that oil can pickup heat from User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 07-20-2020, (Subject: Oil Temp Overheating issue ) Post: #32 | |||
| RE: Oil Temp Overheating issue On a normal day my oil temp just gets to 200 or just hair over. Even on a pull like Mont Eagle I barely get to 225, and my fan hardly ever kicks on because of water temp. | |||
| 07-21-2020, (Subject: Oil Temp Overheating issue ) Post: #33 | |||
RE: Oil Temp Overheating issue (07-20-2020 )Brock Wrote: With the probe on the manifold externally, I never really see over 500 degrees. I'm sure I could get it to climb more on hills but I climb at 1800-1900 rpm. something does not add up with that.. high oil temps and colder than normal manifold temps usually a sign of too high injection timing (or too much boost/running too lean) for the application. That could be dangerous. Make sure you don't have a slipped cam or something else that effects injection timing going on. Also might want t verify your pyro readings with a temp gun at some point to ensure your reading are correct. 500 seems low, even for the outside of the manifold. - I know it would bother and scare the he#$ll out of me if i saw oil temps getting 240+ and only saw 500F on the manifold. i would be concerned as crap about my pistons/cylinders possibly getting tortured. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 07-21-2020, (Subject: Oil Temp Overheating issue ) Post: #34 | |||
RE: Oil Temp Overheating issue (07-21-2020 )Rawze Wrote:Running 38psi boost.(07-20-2020 )Brock Wrote: With the probe on the manifold externally, I never really see over 500 degrees. I'm sure I could get it to climb more on hills but I climb at 1800-1900 rpm. Got my cam, timing wedge and injector test kits on order right now, hoping to see them for days off then I'll be reading into this thing a bit. I'll keep you posted with what I find. I did notice when I was in Calterm these inactive codes so I'm fixin to check into this. That VG code seems to only pop up when I first upload to ECM, I've been having issues lately with a error code after uploading the cal to the ECM so I assumed it had something to do with that. I'm assuming my dumb ass must have forgot to unlock the ECM before downloading one time so I'm going back to a earlier cal to try that. Lots to do this set of days off. User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
| 07-21-2020, (Subject: Oil Temp Overheating issue ) Post: #35 | |||
| RE: Oil Temp Overheating issue My Prostar hauling the same weights ran a way cooler oil temp than my big nose heavy breathing Pete, Prostar was 600hp and this Pete is 500 so who knows... User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
