| 06 CM870 450 ISX egr tuneup |
| 09-30-2019, (Subject: 06 CM870 450 ISX egr tuneup ) Post: #28 | |||
RE: 06 CM870 450 ISX egr tuneup (09-29-2019 )DDlighttruck Wrote: Top picture is all the way to the top. It is likely it will not always go all the way exactly 100% back to the top position on its own with engine just idling sometimes (maybe within 20% or so though/rough guess)... BUT if it is sticking hard at 100% during engine idle with the actuator disconnected ... it is definitely hanging up, something is bad!. A healthy CM870 turbo, the arm will drift back up on its own most the way back to the top when you let go of it. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 09-30-2019, (Subject: 06 CM870 450 ISX egr tuneup ) Post: #29 | |||
| RE: 06 CM870 450 ISX egr tuneup It didn’t feel sticky or rough, whether by hand or with the actuator. If I moved it to the up position, it would stay there. I’m trying to remember now, I think I made sure it was up before firing the motor. The only time I would have to move it up was to get it past where it would stick returning on its own User's Signature: I have no idea what I’m doing and probably need supervising | |||
| 09-30-2019, (Subject: 06 CM870 450 ISX egr tuneup ) Post: #30 | |||
| RE: 06 CM870 450 ISX egr tuneup if the engine is running and you push the vgt closed by hand it takes some force to push it and keep it there. you will also hear the engine change sounds and the turbo start spooling up - its more noticeable with cruise at 1000. if you let go of the arm the engine will push it open back to very close to its starting position. | |||
| 10-02-2019, (Subject: 06 CM870 450 ISX egr tuneup ) Post: #31 | |||
RE: 06 CM870 450 ISX egr tuneup (09-30-2019 )Unilevers Wrote: if the engine is running and you push the vgt closed by hand it takes some force to push it and keep it there. you will also hear the engine change sounds and the turbo start spooling up - its more noticeable with cruise at 1000. if you let go of the arm the engine will push it open back to very close to its starting position. I think I need someone with more experience to check this out then, before I condemn any parts Thanks User's Signature: I have no idea what I’m doing and probably need supervising | |||
| 10-16-2019, (Subject: 06 CM870 450 ISX egr tuneup ) Post: #32 | |||
RE: 06 CM870 450 ISX egr tuneup (09-26-2019 )Chamberpains Wrote: Cummins Insite has a on/off test to check all the plumbing from the control module to the actuator. I had a shop give me a hand with this today. It appears as if my actuator is leaking air, but everything else appears to be ok. Thanks for the info on how to test the other half, from the controller to the actuator. They said don’t worry about the turbo, just replace the actuator. User's Signature: I have no idea what I’m doing and probably need supervising | |||
| 10-16-2019, (Subject: 06 CM870 450 ISX egr tuneup ) Post: #33 | |||
| RE: 06 CM870 450 ISX egr tuneup I just had to do this to my 870 also. Cost $432 for OEM actuator (hope you get a better deal), I don't think you should bother with rebuild kit. If you disassemble yours it will be obvious why. | |||
| 10-17-2019, (Subject: 06 CM870 450 ISX egr tuneup ) Post: #34 | |||
| RE: 06 CM870 450 ISX egr tuneup $432 isn't bad. I paid $500+ from Harrisburg Cummins. Use Cummins genuine only. It is as critical of a part as internal engine parts. Don't skimp on quality. | |||
