| 2003 volvo isx15 cm570 issues |
| 07-05-2024, (Subject: 2003 volvo isx15 cm570 issues ) Post: #28 | |||
| RE: 2003 volvo isx15 cm570 issues Here what cummins showing | |||
| 07-05-2024, (Subject: 2003 volvo isx15 cm570 issues ) Post: #29 | |||
RE: 2003 volvo isx15 cm570 issues (07-05-2024 )tree98 Wrote: You have a bad program and possibly the wrong turbo on your engine. Why are you getting files from a "tuner" your engine is pre emmission so all you need is a factory file with the HP level you choose. Nobody here can help you as long as you have such a butchered up mess.I am not getting any files from ct... Rawze,advised to get calterm and monitor how ecm and engine performing.. | |||
| 07-06-2024, (Subject: 2003 volvo isx15 cm570 issues ) Post: #30 | |||
| RE: 2003 volvo isx15 cm570 issues | |||
| 07-11-2024, (Subject: 2003 volvo isx15 cm570 issues ) Post: #31 | |||
| RE: 2003 volvo isx15 cm570 issues Rawze,Any advises? | |||
| 07-11-2024, (Subject: 2003 volvo isx15 cm570 issues ) Post: #32 | |||
RE: 2003 volvo isx15 cm570 issues (07-11-2024 )Magnat1976 Wrote: Rawze,Any advises? sure .. here ya go... https://rawze.com/forums/showthread.php?...6#pid80246 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 07-11-2024, (Subject: 2003 volvo isx15 cm570 issues ) Post: #33 | |||
| RE: 2003 volvo isx15 cm570 issues Ok,you have solution for that bug? | |||
| 07-11-2024, (Subject: 2003 volvo isx15 cm570 issues ) Post: #34 | |||
RE: 2003 volvo isx15 cm570 issues (07-11-2024 )Magnat1976 Wrote: Ok,you have solution for that bug? Replacing old worn fueling and metering solenoids. First of all, someone needs to check to see if that is the actual issue first. Monitoring the fuel control state and the fuel flow(live mg/stroke) will reveal it. Otherwise, assuming blindly that the ecm is cutting fuel back due to ghost solenoid issues without thoroughly testing for it, is noting but wasting your moneys and time on parts that may not be needed. There is a correction that can be made to the programming on the CM871 and newer engines to remove that bug, but there again, .. if solenoids are worn out, they still need replacing to ensure the engine is running correctly. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 07-12-2024, (Subject: 2003 volvo isx15 cm570 issues ) Post: #35 | |||
| RE: 2003 volvo isx15 cm570 issues Hi Rawze,I wrote before.... My actuators replaced half year ago...all 4 brand new cummins, not a rebuild,or reman.. 4 new ones | |||
| 12-03-2024, (Subject: 2003 volvo isx15 cm570 issues ) Post: #36 | |||
| RE: 2003 volvo isx15 cm570 issues Hello,please advise asap.. We did mechanical compression test.. Cylinder#1-500 #2-520 #3-580 #4-600 #5-570 #6-580 Difference between #1 is 20% Is it out of tolerance, critical?I have blow by,not huge,almost no oil consumption. This can cause stumbling, surge,loss of power,and very bad vibration on road speed at 65mp.1500rpm.. | |||
