Liner Height
03-04-2018, (Subject: Liner Height )
Post: #37
RE: Liner Height
(03-04-2018 )same101us Wrote:  I have a cm2250 that broke the plastic coolant tank. Could the air compressor do that or is it my headgasket?
Yep, if the head gasket is bad it can destroy quite a few things. An easy check is to see if you have any exhaust gas in your coolant. You need an intact coolant bottle to do this. Head over to your local NAPA store and ask for a block test kit. Here is one I found on the Walmart website, https://www.walmart.com/ip/COMBUSTION-BL...3=&veh=sem
If there is exhaust gas in the coolant you will know in one second. Been down that road. I tested mine, I have one of these kits with fresh test fluid, no exhaust gas. But, I have gurgling from the coolant and oil on the compressor where it is being blown out of the front cover directly in front of the compressor, where the oil fill tube is.
 Thanks given by: same101us , Chamberpains , Hammerhead
