Are you a Big-Rig Hypermiler ?... |
08-09-2024, (Subject: Are you a Big-Rig Hypermiler ?... ) Post: #37 | |||
RE: Are you a Big-Rig Hypermiler ?... (08-09-2024 )Rawze Wrote: ...and no ... OOG is always more efficient than in being gear and off the throttle down a hill. The engine always consumes more energy slowing down the truck, than it does consuming the 18-20 mg/stroke idling when in neutral. So when off throttle (no EB), IG coasting down a hill, is that 18-20mg/stroke still being introduced or does the ECM hold back the fuel in order to get the rpms down since there is no throttle input and minimal engine load? (08-09-2024 )Rawze Wrote: Its just matter of getting good at when to OOG ... and when not to go OOG for the benefits. I've always OOG coasted as much as I can (up until this recent test), granted I pull on flat ground and the only time I see a good descent would be a size-able overpass, tunnel or bridge. Typically only utilizing OOG when loaded. Just weird that the only thing I've changed in the OOG vs IG coasting. I mean, it's a great problem to have lol, just would like to know what's assisting the MPG. | |||
08-09-2024, (Subject: Are you a Big-Rig Hypermiler ?... ) Post: #38 | |||
RE: Are you a Big-Rig Hypermiler ?... | |||
