Increasing HorsePower -- What You Need To Know |
04-05-2020, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #91 | |||
RE: Increasing HorsePower -- What You Need To Know 73546081 ok, looking at service history, looks like the ECM was replaced by dealership. I am guessing this is why I am having conflicting info. According to Insite Features and parameters: DO Option - 94193 ECM Code -EB90237.08 SC Option - 92727 ECM Name - CM2350A ECM Part# - 5290170 ECM Serial# - 3056443 Control Parts List - 4780 According to Quickserve: ECM Code - EB90021 CPL # - 3664 | |||
04-05-2020, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #92 | |||
RE: Increasing HorsePower -- What You Need To Know ok, so there was an SCR TSB on the truck and part of that was updating the CPL from 3664 to 4780. Now I need to compare EB90237.8 to EB90222.08 to see if they are compatible. any suggestions? | |||
04-05-2020, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #93 | |||
RE: Increasing HorsePower -- What You Need To Know (04-05-2020 )RHeller11 Wrote: ok, so there was an SCR TSB on the truck and part of that was updating the CPL from 3664 to 4780. Now I need to compare EB90237.8 to EB90222.08 to see if they are compatible. any suggestions? The TSB is 'tsb150105' and it shows what program it should be updated to. Program EB90021 is your original program for that engine according to its ser#. The TSB shows EB90237 and a new CPL of CPL4780. Your ECM information/program is correct assuming that you have the updated SCR canister. Might want to check/verify the part# on the SCR element to be sure. ------ As far as comparing EB90237 with EB90222 (looking at 16,484 parameters/settings in the program) ... Literally, the only thing different in the EB90222 program is the higher power/torque. Besides some mundane data-plate options that have no effect on engine, All else is the same. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
04-05-2020, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #94 | |||
RE: Increasing HorsePower -- What You Need To Know (08-14-2017 )Hetdiesel Wrote:(08-14-2017 )Unilevers Wrote: 10 thou is too low, honestly it just wont last. it will go for awhile but you will being doing it sooner than if it would have been at 14 or 15. it will also take very little shi#t and abuse before going quicker. ive gone as high as 18, but that was a specific thing. The hard part is finding the material that is the exact thickness you want. More than likely you will have to get your shims then cut block accordingly. | |||
04-05-2020, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #95 | |||
RE: Increasing HorsePower -- What You Need To Know (04-05-2020 )Rawze Wrote:(04-05-2020 )RHeller11 Wrote: ok, so there was an SCR TSB on the truck and part of that was updating the CPL from 3664 to 4780. Now I need to compare EB90237.8 to EB90222.08 to see if they are compatible. any suggestions? Got it flashed. first time doing it is a bit nerve racking, but all went well. Thanks! | |||
06-20-2020, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #96 | |||
RE: Increasing HorsePower -- What You Need To Know Looking for higher hp esn 79063945, what calibration would be suitable for higher power. the engine being rebuilt rn | |||
06-20-2020, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #97 | |||
RE: Increasing HorsePower -- What You Need To Know (06-20-2020 )thelastking Wrote: Looking for higher hp esn 79063945, what calibration would be suitable for higher power. the engine being rebuilt rn Who's rebuilding it? There are some very specific procedures to follow when rebuilding an isx if you want it to be reliable and last, especially if you're looking for big horsepower. User's Signature: Warranty??? Yeah right, I am the warranty!!! | |||
06-20-2020, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #98 | |||
RE: Increasing HorsePower -- What You Need To Know (06-20-2020 )tree98 Wrote:(06-20-2020 )thelastking Wrote: Looking for higher hp esn 79063945, what calibration would be suitable for higher power. the engine being rebuilt rn Local shop someone recommended to me | |||
06-20-2020, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #99 | |||
RE: Increasing HorsePower -- What You Need To Know (06-20-2020 )thelastking Wrote: Looking for higher hp esn 79063945, what calibration would be suitable for higher power. the engine being rebuilt rn If it is getting rebuilt, I am sure there will be some assemblence of warranty by the shop doing the work... only they can decide the answer to your question... ask them... and if they put a different program in it, find out what program that is and I will be happy to tell you if it is fully compatible or not. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
