| ISX12 fault 0553 |
| 03-06-2025, (Subject: ISX12 fault 0553 ) Post: #1 | |||
| ISX12 fault 0553 to start with the engine is an isx12 esn 75010036 CM2250 demandated in a 2013 pete 365 fault 0553 is active the entire time running the truck. fuel rail pressure currently runs 32,000+/- 1,000 psi at idle. there are no other fault codes present or active. fuel pump actuator test at 2.5 ohm resistance. have installed a clear section of fuel line to check of any air egress. found no air bubbles in fuel. have replace fuel pump actuator with a oem actuator. inspected actuator bore for any defects. no defects present. had the guy that perform the demandate return truck to factory software for test with no change. he stated that it was checked for revision update and was completed at the time. there was no change to fuel rail pressure. had the demandate software reinstalled. have also checked for fuel return line restriction, removed check valve from head drain line and ran fuel into a bucket. have resistance test and load test engine harness to fuel actuator and fuel rail pressure sensor. parts that have been replace or swapped from know good engine; 6 reman fuel injectors (old were leaking) fuel rail pressure sensor new oem fuel rail relief valve (before i was working on it) fuel pump actuator new oem complete fuel pump head swapped from another truck ecm swapped sorry for the long post but the has been an issue for sometime and can't find any resolution | |||
| 03-06-2025, (Subject: ISX12 fault 0553 ) Post: #2 | |||
| RE: ISX12 fault 0553 for all anyone knows, the program may be problematic. copy the file out of the ecm and e-mail it to me for a proper review of what someone did in there. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 03-10-2025, (Subject: ISX12 fault 0553 ) Post: #3 | |||
| RE: ISX12 fault 0553 thanks for the reply. just wondering if you are able to give directions for how to copy ecm file as im not very familiar with the cummins programs for doing software. | |||
| 03-10-2025, (Subject: ISX12 fault 0553 ) Post: #4 | |||
RE: ISX12 fault 0553 (03-10-2025 )swayte Wrote: thanks for the reply. just wondering if you are able to give directions for how to copy ecm file as im not very familiar with the cummins programs for doing software. here is some info towards this... http://rawze.com/forums/showthread.php?t...5#pid72945 Also,. 553 is an over-pressure code. The excess pressure has to come from somewhere. Either the fuel pump regulator is bad, its electrical circuit is not operating (bad delete programming, wiring issues, etc.), or there is pressure back-feeding into the fuel system from the cylinders (leaky injectors, cracked head, etc.). Will the engine pass a fuel leak test after all that work was done to it, EXACTLY as this video shows?... what is the leak rate in 60-seconds???. ref: http://rawze.com/forums/showthread.php?t...3#pid75483 I also recently found out that there are some shops now, who are doing bad deletes on these engines, that are mechanically modifying the fuel pump regulator, jamming it internally so that makes full pressure all the time. These are some kind of especial ignorant, and complete morons out there who are doing engine killing crap like this. Doing resistance and other checks on the regulator will not reveal this. - Replacing the fuel pressure regulator fixes it. | |||
| 03-12-2025, (Subject: ISX12 fault 0553 ) Post: #5 | |||
RE: ISX12 fault 0553 (03-10-2025 )swayte Wrote: thanks for the reply. just wondering if you are able to give directions for how to copy ecm file as im not very familiar with the cummins programs for doing software. Looks like you got the typical Canadanian trash-can tuning file treatment to me. Likely one of those super-duper tuning destruction shops like maybe Puke-its, Diesel$its, or pig-rig, junkSpall, or one of the other big-name crap jobs to me ... or a copy there-of. The program is beyond destructive/harmful and is nothing but absolute garbage. I feel sorry for anyone's engine that whoever did this to has touched. the crap someone shoved in there is not even meant for an ISX12 at all. It looks like a a bunch of trashed-up ISX15 settings combined with a lot of destructive, harmful, oversight, and just plain poke-and-pray ignorant crap, more than anything. == The file is out of date by several years. Many issues from cummins have been solved since then. The base software needs an update. == someone has edited the fuel flow tables to make the ecm give up more fuel than it knows about. This is very bad for several systems and eventually causes harm. == no engine operating mode control re-mapping. = Very harmful, as the engine will perpetually make extra heat and friction all the time trying to warm up the missing DPF can, eventually leading to head gasket failure. == excessive use of blocked fault codes. = Problematic. == egr gas combustion offset logic has not been switched off. = Moderately Harmful. == Aux. emissions, NOX control, Amonia control offsets are all still active. = Efficiency loss + slightly harmful. == injection timing, fuel-air-mix, and other combustion processes have all been left to factory EGR+ settings. = Very harmful, shortens engine life by as much as half once the EGR gas is taken away, especially at higher power levels. == The power and torque curve for the engine has been completely destroyed. It is set to have the engine make more than 1000HP and more than 2500+ ft.lbs. Looks like a kintergartener made this flywheel torque curve map out of a deep desire to destroy the engine as rapidly as possible to me... its like... WTF???>>>.. ![]() (right click and choose 'view image' to see a larger version) ... There are a whole lot of other issues, but those were the highlights. -- No wonder you got issues with the fuel system. It would not surprise me if the cylinder head was not cracked, or some other catastrophic permanent damage has set in now. Red engines do not like being abused this badly... very bad things happen.. and then the truck owner blames the engine for the destruction that happens later on due to someone else's complete idiotic false promises and garbage custom tuning. - This all while often, the same truck owner or shop will also brag about how 'good' their tuning guy is, .. and that they are the most popular/best guy in town. Bad delete programming .. especially out of the great white north.. is absolutely beyond a plague in the trucking industry. No one wants to admit or think that 'they' were the victim of this.. but with a rating of more than 95+% of bad vs. good programs that I review each year ... someone might as well have gambled in the lottery. Your chances of something decent and non-destructive would have been better. -- Welcome to the bad (and totally destructive) delete club!. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
