ISL9 CM2350 EGR issue
04-25-2025, (Subject: ISL9 CM2350 EGR issue )
RE: ISL9 CM2350 EGR issue
But if you weld in a freeze plug at both ends where could it go
User's Signature: Repairing Demandates 1 Truck At A Time
 Thanks given by: Luckyjayb
He said it's leaking externally
Hey, I got an ideah ... FIX IT RIGHT!!!... ITS A FREGGIN FIRE TRUCK.. A PIECE OF EMERGENCY EQUIPMENT!!!!...
REPLACE THE EGR COOLER and its leaky gaskets, pipes, etc!!!.
05-13-2025, (Subject: ISL9 CM2350 EGR issue )
Put a new cooler on it and welded the exhaust sides shut since it is demandated. Thanks for the feedback!
