| isl 9g ecm hr reset |
| 03-19-2025, (Subject: isl 9g ecm hr reset ) Post: #1 | |||
| isl 9g ecm hr reset Hello everyone, I apologize if this topic has been posted before. Was unable to get a definitive answer. I currently replaced the isl 9 g cm2180 ecm with another good known used ecm. Trying to reset hr meter to 6000 hr as the used ecm has 12000 hr. I have searched online but few bits and pieces I gathered are I need to use calterm to change the ecm time parameter[Don't even know what this parameter looks like]. I would be very grateful if someone could point me in the right direction to the get the correct ecfg file and tell me which parameter needs to be corrected for this. Following is the engine info: ISL 9G Cm2180, Current calibration AW90034.34, ecm part#4934710, engine model G6LTAA8.9, Please delete the post if have violated any rules. Just tired of searching for correct information on this for weeks but can't get a straight answer. | |||
| 03-19-2025, (Subject: isl 9g ecm hr reset ) Post: #2 | |||
| RE: isl 9g ecm hr reset re-flash ecm with new software according to the engine ser# {a blank incal file}, WITHOUT THE CHECKBOX ON FOR SAVE/RESTORE SETTINGS, and then restore the old work order/template from the old ecm after it finishes. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 04-08-2025, (Subject: isl 9g ecm hr reset ) Post: #3 | |||
| RE: isl 9g ecm hr reset Good afternoon, Over the past few weeks I have tried multiple times with checkbox unchecked but the ecm time clock is still showing 12000 hr engine hr time. Do I need to calbrate to completely different calibration and then re calibrate it to correct calibration to reset the ecu time parameter? I do not have a copy of the old ecm template presently. If I copy similar truck template with lower engine hours will that overwrite the engine hours? Thank you. | |||
