Cummins insite calibration
10-15-2016, (Subject: Cummins insite calibration )
RE: Cummins insite calibration
That's it exactly Rawze, thanks.
joed2323, if you can't, or don't want to remove the mandate, a custom tune is your best option.
It will void your warantee, but it does not remove or de;ete any components. A well tuned,clean running engine will produce less soot dramatically reducing, but not 100% eliminating, your sensor and after-treatment issues.
You absolutely need to install a bypass filter to help get as much soot out of the oil.
Read this for more info...
http://rawze.com/forums/showthread.php?tid=113
