Front brake question |
Yesterday, (Subject: Front brake question ) Post: #1 | |||
Front brake question The pin highlighted in the picture (that the front shoes ride on) is worn so that when you install new shoes, they don’t sit just right. And it takes a while for the shoes to wear evenly. That spider assy is over $500. And you can’t just replace that pin, as far as I know. Does anyone know if that pin can actually be replaced, or is there another way of dealing with it, without replacing the whole thing. Thanks ![]() | |||
