| 2013 KW T660 PACCAR CODE HELP |
| 04-28-2025, (Subject: 2013 KW T660 PACCAR CODE HELP ) Post: #1 | |||
| 2013 KW T660 PACCAR CODE HELP 2013 T660 1MILLION MILES Truck is running fine but has all these codes. Any help would be much appreciated. Fault Code FMI Description Source First Detected Last Observed Type Status Network SPN-1024 0 Trip Time in VSL Cab Controller - Primary Apr 13, 9:50 PM Apr 13, 9:50 PM Intermittent Closed j1939 SPN-1231 9 J1939 Network #2 Cab Controller - Primary Apr 16, 1:41 AM Apr 16, 1:41 AM Intermittent Closed j1939 SPN-1231 9 J1939 Network #2 Cab Controller - Primary Apr 21, 8:38 PM Apr 21, 8:38 PM Intermittent Closed j1939 SPN-1231 9 J1939 Network #2 Cab Controller - Primary Apr 19, 5:05 PM Apr 19, 5:05 PM Intermittent Closed j1939 SPN-1231 9 J1939 Network #2 Cab Controller - Primary Apr 23, 9:40 PM Apr 23, 9:40 PM Intermittent Closed j1939 SPN-1481 9 Source Address of Controlling Device for Brake Control Cab Controller - Primary Apr 23, 9:40 PM Apr 23, 9:40 PM Intermittent Closed j1939 SPN-1483 9 Source Address of Controlling Device for Engine Control Cab Controller - Primary Apr 23, 9:40 PM Apr 23, 9:40 PM Intermittent Closed j1939 SPN-1675 2 Engine Starter Mode Cab Controller - Primary Apr 23, 9:40 PM Apr 23, 9:40 PM Intermittent Closed j1939 SPN-17096 0 HVESP23 Bus Voltage Negative to Chassis Ground Voltage Cab Controller - Primary Apr 26, 8:47 AM Apr 26, 8:47 AM Intermittent Open j1939 SPN-17096 0 HVESP23 Bus Voltage Negative to Chassis Ground Voltage Cab Controller - Primary Apr 14, 9:55 AM Apr 16, 3:59 PM Intermittent Closed j1939 SPN-17590 0 HVESP11 Module Current 18 Cab Controller - Primary Apr 26, 8:52 AM Apr 26, 8:52 AM Intermittent Open j1939 SPN-17590 0 HVESP11 Module Current 18 Cab Controller - Primary Apr 14, 9:55 AM Apr 16, 3:54 PM Intermittent Closed j1939 SPN-248 9 Total Power Takeoff Hours Cab Controller - Primary Apr 16, 1:41 AM Apr 16, 1:41 AM Intermittent Closed j1939 SID-251 4 Power Supply Brakes, Power Unit Apr 16, 2:23 AM Apr 16, 2:43 AM Constant Closed j1587/j1708 SPN-256 0 Cab Controller - Primary Apr 16, 3:59 PM Apr 16, 3:59 PM Intermittent Closed j1939 SPN-2795 18 Engine Variable Geometry Turbocharger (VGT) 1 Actuator Position Engine #1 Apr 14, 9:45 AM Apr 14, 9:58 AM Constant Closed j1939 SPN-2863 7 Front Operator Wiper Switch Cab Controller - Primary Apr 19, 1:58 PM Apr 19, 1:59 PM Intermittent Closed j1939 SPN-2863 7 Front Operator Wiper Switch Cab Controller - Primary Apr 25, 7:18 PM Apr 25, 7:18 PM Intermittent Open j1939 SPN-4276 0 Engine Cylinder #10 Exhaust Valve Actuator Cab Controller - Primary Apr 13, 9:35 PM Apr 16, 3:59 PM Intermittent Closed j1939 SPN-4276 0 Engine Cylinder #10 Exhaust Valve Actuator Cab Controller - Primary Apr 26, 8:52 AM Apr 26, 8:52 AM Intermittent Open j1939 SPN-627 4 Power Supply (Obsolete) Brakes - System Controller Apr 16, 1:41 AM Apr 16, 1:41 AM Intermittent Closed j1939 SPN-639 2 J1939 Network #1, Primary Vehicle Network Brakes - System Controller Apr 23, 9:40 PM Apr 23, 9:40 PM Intermittent Closed j1939 SPN-639 14 J1939 Network #1, Primary Vehicle Network Brakes - System Controller Apr 23, 9:40 PM Apr 23, 9:40 PM Intermittent Closed j1939 SPN-768 0 Transmission Range High Actuator Cab Controller - Primary Apr 16, 2:44 AM Apr 16, 3:59 PM Intermittent Closed j1939 SPN-829 3 Left Fuel Level Sensor Cab Controller - Primary Apr 23, 1:58 PM Apr 26, 8:49 AM Intermittent Open j1939 | |||
| 04-28-2025, (Subject: 2013 KW T660 PACCAR CODE HELP ) Post: #2 | |||
| RE: 2013 KW T660 PACCAR CODE HELP I can't make heads or tails of all those trash codes all mixed together into a jumbled pile from that third party software. Maybe make individual lists of cab controller faults, then engine faults, other module faults like tranny, j1939 specific, etc.etc.seperately?. At least then someone could at least somewhat read that mess. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
