| CT ECM codes |
| 05-08-2025, (Subject: CT ECM codes ) Post: #1 | |||
| CT ECM codes I was messing around on CT today and was curious if their ECM code numbers were like insite…For example in insite your ECM code is HD10218.19 and the last two numbers is just a newer ECM code calibration. In CT I have a 60.70.17.70 which should theoretically be the same as HD10218.19 in insite. So is CT code 60.70.17.15 the same base code but just an older version of the calibration? | |||
| 05-08-2025, (Subject: CT ECM codes ) Post: #2 | |||
RE: CT ECM codes (05-08-2025 )Fleetman13 Wrote: I was messing around on CT today and was curious if their ECM code numbers were like insite…For example in insite your ECM code is HD10218.19 and the last two numbers is just a newer ECM code calibration. In CT I have a 60.70.17.70 which should theoretically be the same as HD10218.19 in insite. So is CT code 60.70.17.15 the same base code but just an older version of the calibration? Those are questions better left to be discussed over on the mumble server. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 05-08-2025, (Subject: CT ECM codes ) Post: #3 | |||
RE: CT ECM codes (05-08-2025 )Rawze Wrote:(05-08-2025 )Fleetman13 Wrote: I was messing around on CT today and was curious if their ECM code numbers were like insite…For example in insite your ECM code is HD10218.19 and the last two numbers is just a newer ECM code calibration. In CT I have a 60.70.17.70 which should theoretically be the same as HD10218.19 in insite. So is CT code 60.70.17.15 the same base code but just an older version of the calibration? I can’t seem to get mumble to work on my phone. It doesn’t give me an option to add your private server. I’ll will install on my laptop one day next week and we’ll link up. I need to pick your brain any how! | |||
| 05-09-2025, (Subject: CT ECM codes ) Post: #4 | |||
RE: CT ECM codes (05-08-2025 )Fleetman13 Wrote: ... make sure its an official version and not a fake version. There should be the option to "Add server" ... or perhaps a '+' symbol to add it when looking at the public list or favorites screen. the server name is... mumble.rawze.com User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
