Cm870 Throttle problem |
Yesterday, (Subject: Cm870 Throttle problem ) Post: #1 | |||
Cm870 Throttle problem I have 2007 Cm870, have an issue with the throttle, intermittently gets stuck at 6% which cuts out the Jake’s and jerks the truck while driving. I have swapped sensors, pedal assembly, and checked the wiring. Which all checks good. Could it be the ecm? Or something else | |||
Today, (Subject: Cm870 Throttle problem ) Post: #2 | |||
RE: Cm870 Throttle problem someone power-washing under the hood will do it... gets moisture in the firewall connectors. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
