Ecm issue
10-27-2025, (Subject: Ecm issue )
Ecm issue
I just put an x15 cpl 5880 out of a 2024 international into my 2018 567 pete that had x15 cpl 4343 what do I need to do to make it work?
RE: Ecm issue
Changing the calibration, even with the same CPL, can be dangerous for the engine (issues with the aftertreatment system, turbocharger damage, airflow table problems... ), and the issues increase if the critical components for which the calibration was designed are changed.
This reading might be helpful:
https://rawze.com/forums/showthread.php?tid=1
It seems that those CPLs don't Exist (5880, 4343)
RE: Ecm issue
also, what is the engine ser# of the old engine.. and of the new one?. - that way I (and others) will know what engines that you are referring to exactly.
... and if the truck is de-mandated or not.
RE: Ecm issue
Old engine 80020974 cpl4343
New engine # 80477559 cpl 5880
RE: Ecm issue
Neither de-mandated
RE: Ecm issue
I just changed out a bad engine for a good one. I think I may have figured it out it needs calibrated to the truck I put it in.
RE: Ecm issue
Thanks much
RE: Ecm issue
(10-27-2025 )JTX Wrote:  Old engine 80020974 cpl4343
old esn 80020974 comes back to an X15, CM2350 BGT engine.
new ESN comes back to an X15, CM2450 BKR engine.
These 2 engines are nothing similar whatsoever.
(medaphor)-Just because they both might say 'Ice Cream' on the outside of the carton,.. does not mean they are the same. One might be chocolate... and the other might be lemon or bacon flavored inside it.
Those 2 engines are not even in the same technology with each other /.., and especially so for the the engine control modules.
The older BGT Cm2350 ECM will run that newer BKR engine model internals with no problems ... so ... What needs to happen is that you need to use the wiring harness and ecm from the old engine on the new long-block and not use the newer wiring or ecm. Then a custom program needs to be written for the older ecm that will properly run that ewer model engine. The older ecm will also already be set up correctly for the truck, oem harness wiring, dash, J1939, etc. and everything else.
I typically end up writing custom programs for those type of 'completely different model engine' swaps many times a year for people, even sometimes for stealers$its because they just don't know any better and end up putting in an engine that is not even remotely compatible with the one they took out,.. simply because they both had the letters 'ISX' on the side off them, not knowing any better. They think that they are mostly the same somehow, but this is a as far from the truth as it gets.
Also the emissions systems are NOT going to be compatible at all.. and it is just as illegal to try to run the old emissions systems on the new engine as doing s delete.. so a de-mandate will also have to be done to get it running right as well (can be done when new program is made for older ecm). This means that If you wanted to keep it 100% legal.. then you needed to source a replacement engine that is the same make/model era (a BGT engine) as the old one instead of trying to put a completely different model engine in the truck.
 Thanks given by: JTX
RE: Ecm issue
Ok so I'm past that point now can you help me out?
