Slop when I let off the pedal
07-26-2026, (Subject: Slop when I let off the pedal )
So in noticing a slop when I let off the pedal while driving and it’s noticeable when I’m hooked up to a trailer but worse when bobtail. What do I need to do check ?
RE: Slop when I let off the pedal
slop in what>?... tranny?, engine?, the hood?, rear ends? ???
maybe some history, what engine/truck, etc. too?.
Yesterday, (Subject: Slop when I let off the pedal )
(07-26-2026 )Rawze Wrote:  slop in what>?... tranny?, engine?, the hood?, rear ends? ???
2003 international 9900i with an ISX,13 speed,3.90 rears. I’m guessing the slop is in the drivetrain somewhere and it’s especially noticeable in first gear when I let off the pedal to the point where I get pulled forward from my chair.
Today, (Subject: Slop when I let off the pedal )
I had a front differential that had a lot of slop in it. People said it was normal but I replaced it with one from another remanufacturer. I’m not knowledgeable in taking those apart and making adjustments.
I have had motor mounts cause that but realistically you should check your entire drive line motor mounts u-joints differentials hell even suspension bushings could cause slop. I have even seen bolts all but 3 of the bolts rattle out of the transmission bell housing that that made a truck drive like what could be called slop... really online not being able to see it its anyone's guess
