2010 isx cm871
11-18-2026, (Subject: 2010 isx cm871 )
2010 isx cm871
Jakes, cruise control doesn’t work at all and speedo meter stays at 0. What’s the probable causes? Truck is a w900l
RE: 2010 isx cm871
Someone lost all the vehicle settings in the ecm after a re-flash or bad de-mandate?.
RE: 2010 isx cm871
VSS. The speed sensor on your transmission output. Speed zero = no cruise and no jakes.
RE: 2010 isx cm871
(11-18-2026 )Rawze Wrote:  Someone lost all the vehicle settings in the ecm after a re-flash or bad de-mandate?.
It’s not deleted at all.
RE: 2010 isx cm871
(11-18-2026 )Nostalgic Wrote:  VSS. The speed sensor on your transmission output. Speed zero = no cruise and no jakes.
I had a clue that was the problem, the same happened to my 9900 eagle and that was the culprit. Just wanted to make sure it wasn’t anything else. Thanks for reply
