Checking your Metering and Fueling Actuators by Rawze... |
03-06-2017, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #19 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... those pressure regulators are fairly cheap and easy to replace | |||
03-13-2017, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #20 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... Just replaced front metering actuator and now it's running rough. Is it just a bad one or is there a trick to them. Old one was leaking | |||
03-13-2017, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #21 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... They take a few min to clear out cause if air in the system, or at least mine was like that. | |||
03-13-2017, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #22 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... It never did clear up. Drove it about 40 miles total. When back to cummins and got my old one. Finally got the old one to stop leaking truck runs smooth | |||
05-15-2018, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #23 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... Rawze, I can’t see the pics in your post...... do you have any idea why? Just lil blank boxes. | |||
05-15-2018, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #24 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... I've noticed that happens with older posts.... sucks! I wasn't sure if that was just cause I'm always using my phone instead of a pc. User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
05-15-2018, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #25 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... Yes, it probably is your phone. Or your web browser on your computer. If you leave it over the dot and refresh your screen you'll see the image for a second before it's cancelled back out. | |||
05-17-2018, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #26 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... (05-15-2018 )Chamberpains Wrote: refresh your screen you'll see the image for a second before it's cancelled back out. That’s exactly what happens to me sometimes. Don’t know why. What I do then is , touch it and wait for the menu to pop out. Then hit “save picture “. Then go to the pictures gallery app to open it. User's Signature: I Need to start asking my stupid questions | |||
05-17-2018, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #27 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... Try a different web browser. | |||
