Checking your Metering and Fueling Actuators by Rawze... |
06-10-2020, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #37 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... (06-10-2020 )CandianJake Wrote: I will get CT and send you the programing. i PM'd you the name of who i believe did the programing. Hopefully it will not be as bad as the last 870 tune i reviewed... http://rawze.com/forums/showthread.php?t...6#pid54046 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
07-30-2020, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #38 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... I am looking at doing this to truck. Which ones are the time and fuel actuators? when disassembly is it just the 2 bolts that hold them together? Is there a rebuild kit available for the internal parts? my motor is 871. | |||
07-30-2020, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #39 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... Metering are the outside 2, timing are the inside 2. You are correct - 2 bolts on the back side of each and they can be seperated. There is not a rebuild kit or parts for them that I know. | |||
07-30-2020, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #40 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... Thank you. After rereading the Technical Directive I might be better off replacing with new ones. I'm double past the mileage that they were out. I would still like to take them off and check this out. Maybe i can build one out the 4 four just to have a spare? | |||
07-30-2020, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #41 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... They are exchange parts and fairly pricey. I would at least try to check them out, clean them up and rotate the plungers. See if anything improves. | |||
07-30-2020, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #42 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... I will clean them up then. Nothing is really going on. Truck is not running rough, just losing MPG. Looking on here just to find a starting point on where to find it. I haven't replaced or cleaned these since I bought the at 280k miles, the truck has 1.1M on it now. I have dropped 8.3 avg to 8.0 avg. | |||
07-30-2020, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #43 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... In the pictures with the dial indicator, where did you get the clamp that is holding it? | |||
07-30-2020, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #44 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... I just got quoted $590 per actuator. Holy beejebus they went up in price. I bought four 4 years ago at $460 per.... | |||
07-30-2020, (Subject: Checking your Metering and Fueling Actuators by Rawze... ) Post: #45 | |||
RE: Checking your Metering and Fueling Actuators by Rawze... where from? | |||
