Cam and injector upgrades
11-22-2016, (Subject: Cam and injector upgrades )
Does anyone know if interchangeable parts in the 15 liter x family and possible gains?
Like a QSX cam and injector, or piston with possible lower compression. I'm contemplating a performance oriented cm870 build, lookin to see what's out there, I'd like to get compression down, maybe a better valve/jake cam too. Not lookin for the most fuel efficiency necessarily. Just more performance, kind of a toy.
Thanks
11-23-2016, (Subject: Cam and injector upgrades )
RE: Cam and injector upgrades
Cm570 Pistons are a lower comp I believe
Don't mean to hijack, but would 570 pistons in an demandated 871 help lower EGTs?
(11-23-2016 )Signature620 Wrote:  Don't mean to hijack, but would 570 pistons in an demandated 871 help lower EGTs?
Not really, that comes down to correct boost and timing combined with minimal back pressure . Slightly lower comp would allow higher boost pressure to help maintain a better AFR . Have to be pushing some serious hp to run into egt problems with a vgt and stock Pistons with an 871
