Cummins insite
11-25-2016, (Subject: Cummins insite )
Cummins insite
I'm looking for insite for my truck, 2010 prostar with a cummins. I'm looking at all the different threads with, and it is a little confusing. I want to hook it up to a dedicated computer. I want to be able to monitor the truck as I'm going down the road. Would this information be displayed as text or gauges? Also what plug do I have where the computer hooks up?
While I'm asking computer questions, is there a way I take the software from my Rand McNally gps and put it on my computer or head unit.
11-26-2016, (Subject: Cummins insite )
RE: Cummins insite
Insite shows data in a monitoring screen, but it is number like on a spread sheet, not gauges.
If you just want to monitor stuff like fuel mileage, boost, etc... Get a scamgauge or a roadrelay. No fuss with laptops and such, they just plug in and work.
I have seen these before. They are kinda nice.
https://cumminsengines.com/roadrelay
and these (I don't like em so much, but they are better than not having a display. I.E. Prostar).
https://www.scangauge.com/products/scangauge-ii/
RE: Cummins insite
I have one of these and find it lacking. The mpg it goes good up into the 30s.
RE: Cummins insite
Is anyone using power spec from cummins?
RE: Cummins insite
if being able to monitor things going down the road with a laptop you may want to
look at this.
http://www.silverleafelectronics.com/node/34?q=node/9
the software is free, i have used it in the past, am thinking lately of getting a MS Surface
and running this again could also load Insite on the the surface I believe
