Low oil pressure gen 2 |
11-26-2016, (Subject: Low oil pressure gen 2 ) Post: #1 | |||
Low oil pressure gen 2 Hello all. Having oil pressure issues with a gen 2. Engine will show low pressure on gauge and in ecu, turn it off and leave it for 10 mins then start and it reads normal again for a while. Is this a symptom related to the oil thermostat or bypass system?. Cheers Matt | |||
11-26-2016, (Subject: Low oil pressure gen 2 ) Post: #2 | |||
RE: Low oil pressure gen 2 Oil pressure sensor? Air getting into the oil pump after a bit? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
11-27-2016, (Subject: Low oil pressure gen 2 ) Post: #3 | |||
RE: Low oil pressure gen 2 you need manual gauge to check the real pressure so you know | |||
