cm 870 six Delta p sensor
03-08-2016, (Subject: cm 870 six Delta p sensor )
RE: cm 870 six Delta p sensor
(03-07-2016 )Unilevers Wrote:
(03-07-2016 )marek4792 Wrote:  I have the same code as you pid411 "value too high" and/or "electrical" and I was wondering if it is also effecting boost even if the mandate blocked off?
if the mandate is properly removed, then no - that code will disappear and not effect anything.
I only did the mechanical part of the "mandate" and nothing to the ecm except had the latest calibration installed cpl 8287 500hp 1600ftlbs, sorry for not giving you enough info.
