isx cracked head
12-11-2016, (Subject: isx cracked head )
isx cracked head
would like to get in touch with gear
head or rawze about my 871 isx that had a cracked head
RE: isx cracked head
Did you have the head sent out and found it cracked? If so was it crack around where the injector cups pass through?
Mr Hagg is also a guru recommended shop & member around here...you won't go wrong asking his guidance.
Why don't you post your questions, comments, and pics if you have so we can all contribute or learn?
That is why we're all members here.
 Thanks given by: fargonaz
Hammerhead thanks but IM byfar any guru. I just know people who are lol....
 Thanks given by: Jbonus505
12-12-2016, (Subject: isx cracked head )
(12-11-2016 )little john Wrote:  would like to get in touch with gear
I PM'd you my number.
(12-11-2016 )Mr Hagg Wrote:  Did you have the head sent out and found it cracked? If so was it crack around where the injector cups pass through?
dont know ended up getting a reman engine. now im interested in getting mm done remotely, any help would be apreciatted
12-14-2016, (Subject: isx cracked head )
I spoke to him on the phone. He is getting 42+ psi on his CM871. Place he had it swapped, re-used the ECM. It is a big-name bad delete, destroyed the old engine, and and it is on its way to destroying that reman engine he has now too.
He is only local company / log truck, and cannot take it across country to get it fixed. He does need remote tuning. I told him to contact Gearhead or Unilevers.
He needs to also get a pyro gauge on it like my videos show, and re-establish coolant flow to the rear of the engine block, because those bas##$ard at {big-name company removed} morons removed his EGR cooler and blocked off the coolant flow to the rear of the engine. He also has to fix his exhaust manifold because they removed the original and modified it/ disabled the exhaust back-pressure sensor, and the old engine dropped a valve because of it.
---- ALL,.. AND I MEAN EVERY SINGLE F#$#$KING ONE OF THOSE WELL ADVERTISED, BIG NAME DELETE COMPANIES ARE NOTHING BUT IGNORANT BUTCHERS!!!
ALL OF THEM!
I cannot scream it loud enough!!!
 Thanks given by: fargonaz , 386lover
12-16-2016, (Subject: isx cracked head )
Spoke with unleiver. And gearhead both this week very nice people.
Im going to try to get set up with unilever this Tuesday to remote look at my tune and see what needs done . I appreciate every ones help here . Great people . And I have been staying up way to late at night reading posts on here. Love the site. Thanks for getting it going rawze. You guys are awesome
