NEW FAULT CODE 2215 |
12-13-2016, (Subject: NEW FAULT CODE 2215 ) Post: #1 | |||
NEW FAULT CODE 2215 Just need some advice before I go spend my Xmas money on my truck. I know on the last post i did Rawze said i would need to replace the gear pump and lift pump but when I called the dealer that act like they never heard of a lift pump so may I was wondering if it was called a transfer pump part#4925092 &4925013 quickserve says i need 1 or do i need both of them. also should I change the pressure sensor. I am getting white smoke out the pipe and loss of PSI and here is my engine serial #79288044 also posted a picture. Thank you!!!!! ![]() User's Signature: I stand on a square, I am always seeking light... Just old traveling man lost in the wilderness my compass is pointing me to the East!!!! | |||
12-14-2016, (Subject: NEW FAULT CODE 2215 ) Post: #2 | |||
RE: NEW FAULT CODE 2215 gear pump is part# 4089163 Lift pump is part# 4935013 ================== You might want to read through this thread too... http://rawze.com/forums/showthread.php?t...15#pid8415 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
12-14-2016, (Subject: NEW FAULT CODE 2215 ) Post: #3 | |||
RE: NEW FAULT CODE 2215 (12-14-2016 )Rawze Wrote: gear pump is part# 4089163 Thanks Rawze!!!!!!!!!! User's Signature: I stand on a square, I am always seeking light... Just old traveling man lost in the wilderness my compass is pointing me to the East!!!! | |||
