Where to purchase cummins insite
03-03-2016, (Subject: Where to purchase cummins insite )
Where would anyone suggest to purchase cummins insite and anything else needed to use the software?
Thanks in advance.
RE: Where to purchase cummins insite
ebay comes to mind. A lot of people here have gotten it from there. Maybe a couple others can chime in with some suggestions/pics of what they got
There was a forum member that got one cheaper than ebay from Aliexpress.com and it worked good for him.
Bought mine on eBay , seller is 2013obdfactory, paid $279.00
Please try to find a seller that you can communicate with after the sale. I have had nothing but trouble trying to get it up and running from a seller on ebay.
For the time being I purchased this
BAFX Products 34t5 Bluetooth OBDII Scan Tool for Android Devices
by BAFX Products
here
http://www.amazon.com/gp/product/B005NLQ...ge_o00_s00
Hooked it up with one of the connectors (J1939) from the kit and downloaded cummins fault advisor to my android phone.
Pretty slick set up to get get the basic codes in computer, it can even clear some of them
03-04-2016, (Subject: Where to purchase cummins insite )
Here's a link for Insite.
http://www.buyobdtool.com/wholesale/cumm...6-772.html
{information removed}
03-05-2016, (Subject: Where to purchase cummins insite )
You can get Cummins Insite for free (Software only) at insite.cummins.com, 3GB download.........but you have to buy the subscription from either a Cummins Rep, or one of the other non-legal sites......
Hardware...eBay, AliExpress come to mind....
User's Signature: You want how much?
03-06-2016, (Subject: Where to purchase cummins insite )
Can the inline 5 insite 7.62 be used on the cm2250?
(03-06-2016 )Jerzy609 Wrote:  Can the inline 5 insite 7.62 be used on the cm2250?
yes
