Battery's
01-26-2017, (Subject: Battery's )
RE: Battery's
Chapter 13 in my book..
Vibration and motion may not be so good for your connectors but it actually helps batteries. Lead-acid batteries actually perform better when the acid gets regularly 'stirred up' by the motion of a vehicle. Did you know there are 3 basic types of batteries for trucks? There are starting batteries, deep-cycle batteries, and hybrid batteries. Most trucks you see have starting batteries.
These type of batteries are designed to provide a lot of power all at once in quick, short bursts. Most of the time they are rated more for their 'Cold Cranking Amps', rather than for their 'Amp Hours'. All lead-acid batteries loose the amount of power available as they get colder, so starting batteries with really high 'Cold Cranking Amps' will help get your truck started in below freezing temperatures.
The downside of these batteries is that they are not designed to provide constant power. The more powerful the cold cranking amps that a battery has, the thinner the lead plates are inside the battery. They make the plates thin so that more of them can be placed inside. The more plates, the more cold cranking amps. Because they are so thin, it is easy for them to overheat internally when there is a slow, constant drain on them. This means that when your truck is turned off and you are using power from them to run an inverter or anything else that needs a significant amount of constant power, you are likely shortening the useful life of those batteries. It should also be noted that most starting batteries will only tolerate being completely discharged a few times before being irreversibly damaged.
Deep-cycle batteries are designed to provide power on a more constant basis. The lead plates inside these batteries are thick, keeping them from overheating, but because of this, they have a lot less cold cranking amps. This means they will make starting your truck a bit harder, especially in colder weather.
You can certainly use deep-cycle batteries in your truck if you need more constant power, but you might need to do a couple of things to ensure you do not have problems. It is possible you may need to add an extra battery to overcome the lower cranking amps, and/or you might also need to replace your starter with an after market 'Geared Starter'. Geared starters require a lot less cold cranking amps to get your truck started.
Denso makes some pretty good after-market gear reduction starters for class-8 trucks, so if your starter ever does go out, it wouldn't be a bad idea to get one of these vs another OEM. Hybrid batteries come in a few different flavors. They are an attempt to get the best of both high 'Cold Cranking amps' and still provide a decent amount of continuous power without overheating.
Sometimes these type of batteries are referred to as Gel-cell, Nickel-Cadmium, or Glass-Matt (AGM) batteries. Gel-cells are pretty good batteries for extreme environments and off-road use, as the liquid inside is fixed in place. One of the problems with gel-cells though, is they can be damaged very easily from constant charge/discharge, or from overcharging.
If your alternator produces a slightly high voltage, then it is likely that gel-cell batteries will have a short lifespan in your truck. Nickel-Cadmium batteries are more like Deep cycle batteries except they offer more charge/discharge cycles before they go bad. The downside of them is that they consume a lot of excess energy while charging, costing you fuel. Glass-Matt, otherwise known as AGM batteries, are usually much more expensive.
With their higher price, comes some pretty good benefits though. They are tough, like gel-cells, but they charge more like starting batteries, as well as providing the ability of constant power. They are actually about 25% more energy efficient than any other type of truck battery, actually assisting you in saving fuel as well. These type of batteries are definitely the way to go if you plan on installing any type of sizable inverter because they will pay for themselves long term both in lifespan and energy savings.
No matter what type of batteries your truck has, to be cost effective long term, you need to always ensure that the batteries are not only of the same type, and capacity, but also close to the same age. Keeping your batteries as a 'Matched Set' as much as possible will increase their lifespan greatly. As a comparison to this analogy, think about your truck engine for a moment.
What do you think would happen if each cylinder of your truck engine was a different size and/or type. Your engine would not only run very rough, but the cylinders doing the most work will always cause you the biggest problems. Truck batteries need to be the same capacity, type and roughly the same age to ensure they perform together as a group. Buying used batteries, and/or mis-matching them will only result in more battery problems long term, costing you unnecessarily.
 Thanks given by: fargonaz , gatow900 , Roysbigtoys , RPM1 , Waterloo , PuroCumminsPower , Sergiu , Toolguy
01-29-2017, (Subject: Battery's )
RE: Battery's
All of you fellas planing to use AGM battery on truck, keep in mind that they have different charging characteristics.The truck charging system dos not provide optimal voltage for all charging stages,especially floating stage.Most of them required 14,6+Volts.
My OEM Volvo AGM battery last only 3 winters.If you want to get the best of your batteries, consider additional charger capable to provide proper stage charging.
Just my opinion.
Some Idea below.
 Thanks given by: Rawze , Toolguy
RE: Battery's
I kinda like the setup where you have one ultra cap battery and other three are isolated from the starting cap completely. That way your batteries get charged when truck is running and if they get discharged as long as there is at least 9v to turn on the ecm the truck starts.Those ultra cap batteries will crank a truck for about 15sec i have seen this first hand and really pack a punch. I have installed two. The only part that sucks is isolating all hots and grounds from starter.
01-30-2017, (Subject: Battery's )
RE: Battery's
Keep an eye out at your local truck dealers if you know you will be needing batteries this year. I picked up some very nice East Penn AGM batteries at an International dealer for around $140 ea. They have the FleetRite name on them and were a steal at the time. They normally put these on sale once or twice a year, and they go quick. These normally sell for around $180-$200+ ea in the stearlerships.
RE: Battery's
(01-29-2017 )mmssvv Wrote:  ...
Not sure about that statement. Maybe post a reference to more info from battery maker?
Mine hold up just fine. My alternator peaks at 13.9 v and my inverter/charger cycles spikes them to 14.1 when plugged in, then settles out at 13.2 volts for long term charge.
 Thanks given by: Toolguy
RE: Battery's
I believe some AGM batteries recommend a charge profile for maximum cycles, at the very least you should be maintaining 14.1 volts. At least the batteries I run this is what the manufacturer recommends for Odyssey batteries
https://www.google.ca/url?sa=t&source=we...nF4sMOYcNQ
RE: Battery's
Sorry,my bad!Wrong memory, number is 14,3V in Bulk and Absorption.My truck provide only 13,9v charging voltage and those 0,4-0,3V are still in big play for the battery life.3 years are very low life for AGM Batt. in my opinion.
Below is the charging chart from my OEM inverter XANTREX for references.
Thank You for the correction.
./uploads/201701/post_1075_1485808475_db6c3747132b6606f058f4a2650ab6f0.jpg
Second one is from my solar controller VICTRON Energy BlueSolar MPPT 100/30
./uploads/201701/post_1075_1485809385_fab9123350d85d4be80898dc70811935.jpg
For 12V system divide by 2
 Thanks given by: Rawze , DSTdriver , Toolguy
RE: Battery's
Thanks for providing more info on this,. Everyone can learn from it. That is why I like this forum.
 Thanks given by: mmssvv , DSTdriver , Toolguy
03-08-2017, (Subject: Battery's )
RE: Battery's
If I remove all the batteries how long do I have before they need to be reinstalled?
Want to make sure that I avoid any potential problems.
Thanks
T700
