Exhaust pressure- CM871 |
03-05-2016, (Subject: Exhaust pressure- CM871 ) Post: #1 | |||
Exhaust pressure- CM871 I bought a used 08 and the truck has some serious gremlins. I've done the EGR tuneup, changed some sensors and plugs, and had a few repairs done.. here's the thing, the truck has been very inconsistant. Fuel economy is all over the map ranging from 5.2 to 7.8mpg, load and terrain don't seem to matter whatsoever. Driveability is all over too. Engine doesnt idle great either, surges if you bump it up. Truck will at times pull well at 38 - 40 PSI man press and shift and drive fine, other times it'll pull to almost 50 psi but isn't running shifting worth a damn. In both these instances it may or may not be having an overheating issue. At times both oil and water temps will spike fast when pulling, I can pull it back with the fan. Other times it does fine and just climbs slowly to about 220 oil temp and 210 water temp.(Normal) At other times truck seems to to derate where it will only boost up to 28 PSI, BUT it runs, drives and shifts great, with no heating issues at all. The other day i noticed a small amount of soot on steel line that goes from exhaust manifold to thermostat housing, so I tried to remove line out on the road but the manifold side was not coming out. I ordered a replacement line at my local cummins shop so I could feel free to break it when I got home.Got home, and attempted to remove line,a lot of peneterating oil and heat but still wouldn't budge, just skipping by on flange wrench.I removed the top of the line so I could slide a box end onto it and hmmm, I can wiggle the bottom flange about 1/16" in and out of the bottom fitting that wont budge. Finally removed bottom fitting(And it was super tight all the way out) to find that someone had crossthreaded it and it never had sucked the flange tight.( Read major pressure loss) I repaired the threads , replaced the line, I had already replaced the exhaust pressure sensor. I was originally going to remove line to make sure it wasn't soot plugged, it was clean. I haven't run with it yet, but the truck now idles smooth and a quick bobtail around seems like its running correct, I may have found my red flag! Lets hope so. Remember it's not always software, don't overlook the hardware.. | |||
03-05-2016, (Subject: Exhaust pressure- CM871 ) Post: #2 | |||
RE: Exhaust pressure- CM871 First off, do the complete tune up, everything, not just some. I have the same year motor, let me tell you it creates soot like you have never seen. I have done the work on mine to eliminate much of these issues, ahem. One thing I would do is clean the soot out at least twice a year, along with replacing and or cleaning all of the sensors as needed. I would also remove the cans and have them cleaned, baked, maybe you will get a little more life out of them doing this. They are not difficult to get off, just watch the lines on the sides of the cans, mine snapped/broke right off. I also found those lines were severely clogged with soot, I have no clue how it even was able to regen. If you remove the cans for cleaning, you will need a new gasket set for the cans and the exhaust inlet. Just my .02 | |||
03-05-2016, (Subject: Exhaust pressure- CM871 ) Post: #3 | |||
RE: Exhaust pressure- CM871 (03-05-2016 )Brewster64 Wrote: I bought a used 08 and the truck has some serious gremlins. I've done the EGR tuneup, changed some sensors and plugs, and had a few repairs done.. here's the thing, the truck has been very inconsistant. Fuel economy is all over the map ranging from 5.2 to 7.8mpg, load and terrain don't seem to matter whatsoever. Driveability is all over too. Engine doesnt idle great either, surges if you bump it up. Truck will at times pull well at 38 - 40 PSI man press and shift and drive fine, other times it'll pull to almost 50 psi but isn't running shifting worth a damn. In both these instances it may or may not be having an overheating issue. At times both oil and water temps will spike fast when pulling, I can pull it back with the fan. Other times it does fine and just climbs slowly to about 220 oil temp and 210 water temp.(Normal) At other times truck seems to to derate where it will only boost up to 28 PSI, BUT it runs, drives and shifts great, with no heating issues at all. The other day i noticed a small amount of soot on steel line that goes from exhaust manifold to thermostat housing, so I tried to remove line out on the road but the manifold side was not coming out. I ordered a replacement line at my local cummins shop so I could feel free to break it when I got home.Got home, and attempted to remove line,a lot of peneterating oil and heat but still wouldn't budge, just skipping by on flange wrench.I removed the top of the line so I could slide a box end onto it and hmmm, I can wiggle the bottom flange about 1/16" in and out of the bottom fitting that wont budge. Finally removed bottom fitting(And it was super tight all the way out) to find that someone had crossthreaded it and it never had sucked the flange tight.( Read major pressure loss) I repaired the threads , replaced the line, I had already replaced the exhaust pressure sensor. I was originally going to remove line to make sure it wasn't soot plugged, it was clean. I haven't run with it yet, but the truck now idles smooth and a quick bobtail around seems like its running correct, I may have found my red flag! Lets hope so. Remember it's not always software, don't overlook the hardware.. 41-42 PSI or more boost is too high for any CM871 engine, no matter what the HP is and will start to cause damage. .. but 50+ psi boost is extreme overboost and can crack the head, cause injectors to leak, cook the motor, damage and overheat the turbo, crack pistons, and do a lot of other engine damage. * it can be caused by -- A bad/misreading Exhaust gas pressure sensor (the tube your fighting is the feed-line for it). * it can be caused by -- A VG turbo that is failing and is now unstable. * it can be caused by -- A blocked or failing EGR circuit where the Delta-P sensor is reading too low, or a bad/misreading Delta-P sensor. i have also seen cracked crossover tubes or cracked mounting blocks do this too. ![]() * it can be caused by -- A bad/misreading IMAP (Intake Manifold Pressure Temperature) Sensor. * it can be caused by -- BAD ECM Programming. Especially if you have a bad EGR delete by one of the big-name companies out there. =========== An external pyro and boost gauge is your best friend in letting you know where your fuel mileage and power is going. This future is a very possibility for you,.. If you were driving it under medium to heavy torque loads and fighting that much overboost, then I see an engine failure in your near future. Give it a month or possibly three. That is how long it takes for combustion gases to drill a hole through, and into the bottom of that now cracked piston you may just have in your engine there after driving it like that. ![]() Hopefully you got lucky,.. but i would not bank on luck if you drove it like that for very much. - I would schedule some downtime, do an injector leak-down test, and if any injectors were leaking, pull them all and boroscope that thing to ensure it didn't get damaged. | |||
03-05-2016, (Subject: Exhaust pressure- CM871 ) Post: #4 | |||
RE: Exhaust pressure- CM871 Thanks for the info. I've already changed out both sensors on intake as well as the exhaust pressure sensor, as well as the tubes. The engine is not deleted and has a new ecm programmed to stock 485 cal with updates direct from Cummins. I never let the truck pull when it wanted to run over 40 psi, and made a point of not lugging it when it would heat, shifted down and revved it up to flow air and water. I do think that the bad line was playing havoc with the VGT, Im hoping that it hasn't stressed pistons or head for sure, and if it has we'll be giving the warranty a workout I guess. Going to give it a 4500 mile test drive and see how it does, truck hasn't really run right since I got it, so all I can hope for is improvement at this point. Not feeling the love for it yet, lol. Again, thanks for the info. | |||
