reliable ISX repair shop in WA/OR/CA
02-01-2017, (Subject: reliable ISX repair shop in WA/OR/CA )
Hi , i am looking for a good shop along rout 90/97 om AB to CA been into so many shops that are simply horrible. We have the typical DPF problems, need a new SCR and probably rear seal done. I want someone who will actually do what he is supposed to. Check motor mounts, clutch bottom end etc .. since we have a 25 hour job for the seal anyhow ... lets make it worth while . But i dont want to end up with 10,000$ then i may as well start looking at a complete in frame. Any help is apreciated.
 Thanks given by: overshot
RE: reliable ISX repair shop in WA/OR/CA
If you end up on the east coast, Mr. Hags (Atlanta) or Gearheads (Maryland) shop are both a a good choice.
Dr.ISX is in las vegas, not sure if he does that kind of work, maybe give him a jingle also.
 Thanks given by: cjcool
02-02-2017, (Subject: reliable ISX repair shop in WA/OR/CA )
(02-01-2017 )Rawze Wrote:  If you end up on the east coast, Mr. Hags (Atlanta) or Gearheads (Maryland) shop are both a a good choice.
Pm me im rite in your alley . Pasco, wa
