| Fuel cuts off when tires spin in snow |
| 02-13-2017, (Subject: Fuel cuts off when tires spin in snow ) Post: #1 | |||
| Fuel cuts off when tires spin in snow This truck cuts off the fuel if you start spinning in snow. I don't want it to do that. All it does is get you stuck on a little hill or something you could have made it up. I don't want it to think for me. Sometimes you just need it to keep going. I would think it has something to do with traction control (atc). Before I just start searching through, does anyone know what I should look for in insite or Bendix to stop it? Or am I stuck with it? Thanks. | |||
| 02-13-2017, (Subject: Fuel cuts off when tires spin in snow ) Post: #2 | |||
| RE: Fuel cuts off when tires spin in snow I'm surprised there isn't a switch to disable it. I could certainly see that causing a ####up! User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
| 02-13-2017, (Subject: Fuel cuts off when tires spin in snow ) Post: #3 | |||
| RE: Fuel cuts off when tires spin in snow The only way to disable, besides trying to pull a fuse if there is one, is to connect a laptop with ABS program and turn the feature off. The traction control signal is done by the ABS module. Found this on just answer User's Signature: It's hard to win an argument with a smart person, but it's damn near impossible to win an argument with a stupid person | |||
| 02-13-2017, (Subject: Fuel cuts off when tires spin in snow ) Post: #4 | |||
| RE: Fuel cuts off when tires spin in snow Check calibration FEATURES and PARAMETERS Load based speed control. | |||
| 02-14-2017, (Subject: Fuel cuts off when tires spin in snow ) Post: #5 | |||
| RE: Fuel cuts off when tires spin in snow If this truck is a Volvo. Hit the tcs switch. | |||
| 02-14-2017, (Subject: Fuel cuts off when tires spin in snow ) Post: #6 | |||
| RE: Fuel cuts off when tires spin in snow My prostar has a "offroad" button that disables atc. User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
| 02-14-2017, (Subject: Fuel cuts off when tires spin in snow ) Post: #7 | |||
| RE: Fuel cuts off when tires spin in snow If this is a Paccar product it can easily be disabled with ESA. If not get someone to do it with ABS software like the member stated. | |||
| 02-14-2017, (Subject: Fuel cuts off when tires spin in snow ) Post: #8 | |||
| RE: Fuel cuts off when tires spin in snow | |||
| 02-15-2017, (Subject: Fuel cuts off when tires spin in snow ) Post: #9 | |||
| RE: Fuel cuts off when tires spin in snow The off road button should disable it. | |||
