RE:CM 870 EGR TUNE UP GUIDE
03-01-2017, (Subject: RE:CM 870 EGR TUNE UP GUIDE )
Hi All,
i searched through the forum and cannot seem to find a EGR tune up guide for the CM 870. Please could someone either send me a link if they know where it is?
Need to do one soon.
Thanks
RE: RE:CM 870 EGR TUNE UP GUIDE
What yor looking for is in the videos link above
 Thanks given by: madcash2
870 has intake pressure sensor, delta-P, exhaust pressure, and basically all the stuff like 871. Register your esn# in quickserv and you can see where those parts are on your model engine.
 Thanks given by: madcash2 , hhow55
(03-01-2017 )hhow55 Wrote:  What yor looking for is in the videos link above
which video link sorry? I looked through the videos can only see the 871 tune up. sorry could you kindly post the 870 youtube link if possible?
(03-01-2017 )Rawze Wrote:  870 has intake pressure sensor, delta-P, exhaust pressure, and basically all the stuff like 871. Register your esn# in quickserv and you can see where those parts are on your model engine.
I do have a quickserve account and have checked the parts location. I was just looking for a guide on everything i need to check. Similar to what you have done for the 871.
Thanks
(03-01-2017 )madcash2 Wrote:  I do have a quickserve account and have checked the parts location. I was just looking for a guide on everything i need to check. Similar to what you have done for the 871.
Thanks
Other than the 871 has a DPF where the 870 does not, the EGR tune up is the same procedure (less DPF service of course).
https://youtu.be/FhJxpyS5MpY
Here is part 1. From there you can continue to the other 5.
03-02-2017, (Subject: RE:CM 870 EGR TUNE UP GUIDE )
(03-01-2017 )Brock Wrote:  https://youtu.be/FhJxpyS5MpY
Hey Brock, the link above refers to CM 871 in the video
