| FAULT CODE. 5018. 641-9. |
| 03-08-2016, (Subject: FAULT CODE. 5018. 641-9. ) Post: #1 | |||
| FAULT CODE. 5018. 641-9. We have an 07 International Prostar with a ISX . It had a new turbo , new EGR , and a DPF clean out . We are now getting the fault code of 5018 / Application HDS J1939. After treatment 1 diesel oxidation catalyst system SPN : 5018. FMI : 11. Root cause not known that will not clear ------- we also had Fault code 641-9 cleared easy ------ anyone been here and done this ?? We are learning daily about these engines . Many thanks to all .... Aimee | |||
| 03-08-2016, (Subject: FAULT CODE. 5018. 641-9. ) Post: #2 | |||
RE: FAULT CODE. 5018. 641-9. (03-08-2016 )Aimeesfleetservice Wrote: We have an 07 International Prostar with a ISX . It had a new turbo , new EGR , and a DPF clean out . We are now getting the fault code of 5018 / Application HDS J1939. After treatment 1 diesel oxidation catalyst system SPN : 5018. FMI : 11. Root cause not known that will not clear ------- we also had Fault code 641-9 cleared easy ------ anyone been here and done this ?? We are learning daily about these engines . Many thanks to all .... Aimee You have to do an after-treatment maintenance reset and a forced regen i think. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 10-07-2024, (Subject: FAULT CODE. 5018. 641-9. ) Post: #3 | |||
| RE: FAULT CODE. 5018. 641-9. It worked thanks rawse! | |||
