CM2350 factory file comparrisons...
06-10-2021, (Subject: CM2350 factory file comparrisons... )
Post: #37
RE: CM2350 factory file comparrisons...
(03-06-2021 )Rawze Wrote:
(03-06-2021 )lane458 Wrote:  Was also looking into uprating X15 CPL4343 605hp trucks. I'm thinking 605hp 2050tq is probably the ceiling for the trucks, but it would be nice to squeeze a little more out them if possible with factory files.
the more you up the torque, the shorter the engine lifespan... by a LOT!
At 2050 torque, you'de be doing good to get 650k miles out of a highway truck as it is before the head had to come of it vs. close to a million miles at 1750-trq.
It is far cheaper to replace the rears with a better spec than it is to torture your engine.
Thats what my thoughts were... the more power these guys want out of the motor, the shorter the overall life span is. You'd think once you explain to the driver that you can get a million miles outa your motor vs. 600k they'd want to leave it alone. But they keep on wanting more power... I must be missing something. Most of these guy's trucks are their paychecks, you'd think they'd want to keep them outa the shop.
A side note, most of these trucks aren't flat landers, they fly through the rolling hills of Appalachia. Maybe thats why they're hunting HP? Would re-gearing trucks still be better?
Post: #38
(03-06-2021 )marek4792 Wrote:  What do you have now in it? Running Rough has been tinkering with x15s and actually prefers the 565/2050 file over the 605/1850 version, and performs better than the 605 file. What application are you running? 2050 isn't really needed in most situations and can be overkill.
CPL4343
HD10391.02
Do you have an OS number for the 565 file? I'd love to compare them.
06-17-2021, (Subject: CM2350 factory file comparrisons... )
Post: #39
thank you for doing this, great info put together
whenever you have time
ESN 79847947
CPL 4583
CODE EF10112
08-07-2021, (Subject: CM2350 factory file comparrisons... )
Post: #40
what is the difference between cummins X15 performance 565hp and X15 productivity 565hp?? I want the 605hp rating simply bc it does not roll off torque to early but if the productivity series has other compromises then maybe its not worth it idk??
08-08-2021, (Subject: CM2350 factory file comparrisons... )
Post: #41
(08-07-2021 )KW660_16 Wrote:  what is the difference between cummins X15 performance 565hp and X15 productivity 565hp??.
This thread discusses this ...
http://rawze.com/forums/showthread.php?t...0#pid51650
and where did you get this statement from?...
(08-07-2021 )KW660_16 Wrote:  the 605hp rating simply bc it does not roll off torque to early
That statement does not make any kind of actual sense.
Also, the higher the torque settings, the shorter the lifespan of the engine will be. -- BETTER SPEC'D REARS are the answer to slinging around heavy loads, NOT TORTURING THE ENGINE WITH HIGH TORQUE AT LOW RPM's.
 Thanks given by: KW660_16
Post: #42
We already talked so we're good there. But for someone reading this. I totally agree that low rpm high torque (lugging) is bad. What I mean is if two engines have the same torque ratings but two different HP ratings I want the higher HP rating bc preferably with a lower torque rating actually bc where the ecm likes to produce power is at a higher rpm. I don't have any use for an engine that produces 2050lbft torque from 1100-1400rpm then dies off. Id rather have an engine that produces peak torque at 1400 rpm then SLOWLY reduces as you increase rpm. This is how you reliably produce power in an engine without destroying it.
01-08-2022, (Subject: CM2350 factory file comparrisons... )
Post: #43
I'm new to using insite. How does one change their file from EF10059 to EF10064? Just curious so that I dont accidently change it.
Post: #44
(01-08-2022 )Mudflap77 Wrote:  I'm new to using insite. How does one change their file from EF10059 to EF10064? Just curious so that I dont accidently change it.
If a persons truck has any kind of custom (or de-mandate) programming in it, then it will get lost of you try to flash the ecm with new software.
To change from one program to a different program in Insite, it requires a "fleet count" to unlock the feature and allow such action.
 Thanks given by: Mudflap77
Post: #45
I was worried that it would be easier then accidently entering a random set of numbers/letters that so happened to match passcode they stumbled upon. Thanks for setting my mind at ease Rawze!! LOL
