CM2350 factory file comparrisons...
02-01-2022, (Subject: CM2350 factory file comparrisons... )
Post: #46
RE: CM2350 factory file comparrisons...
Has anyone gone through the cm2450 files yet? Lotta guys with are getting these trucks and compared to 565 cm2350 trucks they had before, says they run a lot worse...
Post: #47
Define "run a lot worse "
Post: #48
(02-01-2022 )lane458 Wrote:  Has anyone gone through the cm2450 files yet? Lotta guys with are getting these trucks and compared to 565 cm2350 trucks they had before, says they run a lot worse...
That sounds to me like what those idiots who hang out on the engine tuning/delete sites would say... because none of them seem to have any clue how to do anything past unplugging crap and making codes dissapear form the dash, then wonder why the engine blows up prematurely. .. or like you said,... runs like crap after such complete half-arssed garbage.
02-02-2022, (Subject: CM2350 factory file comparrisons... )
Post: #49
As far as just generalizing goes ...
Not sure about "worse" .. but there are added features that are not in the CM2350-X15's.. like an added "Predictive road speed Control", "Predictive engine braking", some kind of "Predictive Gear Shift Manager", some new "Passive de-soot assist", some stupid "On-Ramp extra boost" that does more harm than good to the engine at low RPM, and a few other added ramp-rate and attempted "fuel savings" limiters that try to limit how you drive the engine in various ways.
Here is a list of some of the others that are also in these newer engines..
ref: http://rawze.com/forums/showthread.php?t...6#pid63796
02-10-2022, (Subject: CM2350 factory file comparrisons... )
Post: #50
PM me. I need some help/guidance with a truck im working on. It has been deleted and it must not be a good one because its stock power and derated all the time. he want more hp and it to not be derated all i have is a 600 HP tune which i think is to high
02-11-2022, (Subject: CM2350 factory file comparrisons... )
Post: #51
(02-10-2022 )white999 Wrote:  PM me. I need some help/guidance with a truck im working on. It has been deleted and it must not be a good one because its stock power and derated all the time. he want more hp and it to not be derated all i have is a 600 HP tune which i think is to high
You need to start by pulling a copy of the program out of the ecm and send it (e-mail) to me for a proper review.
Post: #52
Ok im sure i might be able to figure that out. where do i get your email. or i can get you my team viewer
Post: #53
(02-11-2022 )white999 Wrote:  Ok im sure i might be able to figure that out. where do i get your email. or i can get you my team viewer
I PM'd you the email address to send any files for review.
04-11-2022, (Subject: CM2350 factory file comparrisons... )
Post: #54
hi i have a 2016 t680 10spd manual trans 3.25 rears engine is a 425st cummins isx cpl4583 ecm code EF10086 im curious whats the highest i can turn it up to and like what calibrations would work on it. i also want to remove that 1800 rpm limiter thats built in to the eco calibrations. including all info about engine from cummins quickserve
Marketing Model Name Service Model Name EPA Model Name
ISX15 425ST ISX15 CM2350 X101 FCEXH0912XAT
Shop Order Build Plant Build Date
SO42434 JEP - JAMESTOWN ENGINE PLANT 04 Aug 2015
Warranty Start Date ECM Code Fuel Pump Part #
27 Aug 2015 EF10086 4359489
Fuel Pump Calibration Marketing Engine Configuration # Technical Engine Configuration #
P947 D103012BB35 D103012BX03
CPL # Customer Number
4583 1442
Injector Trim Codes
Part Number 2897320
Injector 1 Trim Code JJNR4Q86W
Injector 2 Trim Code K6CDNCA26
Injector 3 Trim Code UCK0H2M8A
Injector 4 Trim Code HAM1VK3XW
Injector 5 Trim Code TL1QF67G9
Injector 6 Trim Code PYULN1N42
