CM2350 factory file comparrisons... |
04-18-2022, (Subject: CM2350 factory file comparrisons... ) Post: #64 | |||
RE: CM2350 factory file comparrisons... (04-18-2022 )Lonestar10 Wrote: I have yet to see normal truck tires rated above 75mph if anyone driving over 75 with these tires ever hurts someone driving above tire ratings I hope you are jailed for life... I highly doubt anyone here is purchasing their tires based on speed rating. Most truck rear ends are only rated for about 76 mph as well. Driving 80+ mph in an 80,000 lb piece of heavy equipment purposefully is insane and dangerous. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
05-07-2022, (Subject: CM2350 factory file comparrisons... ) Post: #65 | |||
RE: CM2350 factory file comparrisons... Hey Rawze, with EF10063, you had said that 10069 is compatible and that's 600hp but for an RV and Motorcoach. Can you tell me if EF10068 is compatible with EF10063? Same CPL number but just trying to make sure. Thanks in advance | |||
05-08-2022, (Subject: CM2350 factory file comparrisons... ) Post: #66 | |||
RE: CM2350 factory file comparrisons... (05-07-2022 )greasemnky87 Wrote: Hey Rawze, with EF10063, you had said that 10069 is compatible and that's 600hp but for an RV and Motorcoach. Can you tell me if EF10068 is compatible with EF10063? Same CPL number but just trying to make sure. Thanks in advance EF10063 and EF10068 are also fully compatible. only the power,torque, and torque limit curves are slightly are different ... nothing more. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
06-05-2022, (Subject: CM2350 factory file comparrisons... ) Post: #67 | |||
RE: CM2350 factory file comparrisons... Hey guys I have a friend looking for a power upgrade. He is running a 2021 389 with the ECM code is HD10458. I was wondering if HD10462 was compatible? I believe it is I seen this file in a W900 with the same CPL verified charge ref tables and they match but I am no expert I maybe overlooking something important. The market category his file is rated for is vocational, but he is hauling highway all the time, should I be looking for a linehaul rated ECM code? If someone could also explain to me what the differences are between linehaul and vocational files. I was under the impression a vocational ECM code would be for dump trucks and trucks that do city driving often and linehaul was for highway. If this was the case why is there a vocational ECM code inside this truck that was ordered for highway use? Would this have any effect on fuel mileage and DEF usage? I verified the dataplate and it has the right ECM code, the truck was built with. | |||
06-06-2022, (Subject: CM2350 factory file comparrisons... ) Post: #68 | |||
RE: CM2350 factory file comparrisons... (06-05-2022 )Mikanic Wrote: Hey guys I have a friend looking for a power upgrade. He is running a 2021 389 with the ECM code is HD10458. I was wondering if HD10462 was compatible? Only thing different is the power/torque. They are 100% compatible and have all the same exact settings for their power levels otherwise. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
