Bad Air compressor installation |
04-11-2017, (Subject: Bad Air compressor installation ) Post: #1 | |||
Bad Air compressor installation Hi! I drove on interstate and suddenly start losing air pressure. Call roadside assistance in Akron, OH.They charge my 9 h of labor. guy was calling someone every 30 min because he don't have a glue what he's doing. They didn't turn crankshaft damper in "insert pin position "(I saw Rawze unfinished video on air compressor replacement).He keep telling don't worry i know what I'm doing and timing will be done at air governor, and also they didn't tork bolts to spec they just used an air gun! I want to redone air compressor myself but I'm not sure can I reuse gaskets ( 1 week old) Or better to buy new one? | |||
04-11-2017, (Subject: Bad Air compressor installation ) Post: #2 | |||
RE: Bad Air compressor installation new gaskets for sure. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
04-11-2017, (Subject: Bad Air compressor installation ) Post: #3 | |||
RE: Bad Air compressor installation Also couple days after air compressor installation I find out that pipe from crancase filter start leaking oil in place where pipe conected to engine block. And then I removed crancase filter and there was oil What can cause that? Turbo? | |||
04-12-2017, (Subject: Bad Air compressor installation ) Post: #4 | |||
RE: Bad Air compressor installation Air gun on air compressor bolts? You can barely get to them with a flexible ratchet and wobble extension on some trucks hahah. Good chance he's damaged the tube you speak of, the plastic gets brittle after a while. | |||
