Running generator instead of the apu
06-13-2017, (Subject: Running generator instead of the apu )
Post: #19
RE: Running generator instead of the apu
(06-13-2017 )Jon Mastin Wrote:  Here's mine.
What is brand/model of your generator?
06-14-2017, (Subject: Running generator instead of the apu )
Post: #20
Its a champion 3100 Inverter Generator. I could get away with a 2000 watt but i like the electric start and remote start capabilities with this unit. It'll run 8 hours on a 1.6 gallon tank.
Post: #21
I just bought one of those champions and a 12k window unit that im modifying to place the condensor outside. How did u mount the genset? What u do in the rain?
06-15-2017, (Subject: Running generator instead of the apu )
Post: #22
I just did a simple platform mount. I went with this because i wanted something mounted. Also it doesnt have a "hard start" like a normal A/C because its an inverter setup. The drian and the A/C lines pass thru a 2 inch hole at the top of the sleeper which uses the conduit box and runs down the back.
