de-commissioned doser go bad?
04-18-2017, (Subject: de-commissioned doser go bad? )
On a CM871 with @m*m^2; can the doser go bad and start putting fuel into the exhaust? Is there an easy way to physically block a 300psi fuel line?
RE: de-commissioned doser go bad?
The supply line for the doser is here...
./uploads/201704/post_1744_1492520883_d78cc9aa21fcf2caa0b1f9c93d32c000.jpg
I see a lot of guys with de-mandated trucks take the plug that came out of the intake manifold where they installed a boost gauge and use it to plug the doser line off. If you remove the supply hose (in the picture above) and also the hex-shaped adapter behind it, then the plug fits perfectly into the hole in the IFSM.
 Thanks given by: Waterloo , big_roy , barf , Kiroisx , Nostalgic , B O Double V
