Exhaust manifold leak
04-19-2017, (Subject: Exhaust manifold leak )
I just noticed this leak. Any insight appreciated.
RE: Exhaust manifold leak
Here's another pic.
Valve seal, I have had this type of leak and fixed them twice already.
 Thanks given by: Rawze , PuroCumminsPower
What's the labor look like on a valve seal?
I wouldn't have a number for you since I did it mostly myself, but I would say 3-5 hours labor including an overhead set if you choose to do so. You're looking at $20 in parts 4 seals and injector o-rings per clyinder. The spring compressor tool runs about $400 tho.
Thanks for the information. I appreciate it.
No problem good luck!
